Stuck Brake Clevis Pin
So I'm trying to pull my pedal box to rebuild it and every fastener has come out easily and cleanly except this clevis. No amount of banging or prying can get it to move.
I soaked it with PB Blaster but I haven't tried heat. I can't get my dremel up in there to cut it out. Any suggestions?
1978 911SC with Lobster Interior - Zoidberg
http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html
Old 01-01-2023, 05:54 PM
917_Langheck's Avatar
Is there still compression on the rod? Could be that the pin is worn and captured as if in a detent.
Maybe see if you can fit a small c-clamp with the screw side towards the clutch, fitted on a slight angle, as a press.
Old 01-01-2023, 10:55 PM
Looks like the pin is bent, stick something in the hole like a small Phillips screwdriver and work it back and forth see if you can spin it around
Old 01-02-2023, 04:44 AM
If it won’t budge cut it with a hacksaw blade removed from the frame wrap some tape for a grip.
Old 01-02-2023, 04:45 AM
Can you unscrew the rod from the clevis then remove the cluster? That’d allow you more space to work on removing the pin.
Old 01-02-2023, 07:16 AM
The rod is still under tension, not sure I can unscrew the ends. I may try that.
Old 01-02-2023, 07:18 AM
Grab the head with needlenose visegrips and do the twist.
206 637 4071
Old 01-02-2023, 07:23 AM
I tried the vice grips, nothing. It's welded in there.
I ended up removing the rod by unscrewing it. I'm questioning whether I even bother to replace the clevis since there's no play in the joint and getting it out will be a pain.
Old 01-02-2023, 02:08 PM
Get a better grip.
206 637 4071
Old 01-02-2023, 03:52 PM
It just starts to strip the pin.
Old 01-02-2023, 04:57 PM
Loosen the jam nut first.
Old 01-02-2023, 06:55 PM
Definitely replace the pin while you have everything out. Something bent and jammed in the braking mechanism would give me the willies. I bet you could get something like this in place to pop the pin out now that you have the rest of the assembly out.
https://www.harborfreight.com/3-4-quarter-inch-forged-ball-joint-separator-99849.html?utm_source=google&utm_medium=cpc&utm_campaign=12144811130&campaignid=12144811130&utm_content=117789318958&adsetid=117789318958&product=99849&store=&gclid=CjwKCAiAwc-dBhA7EiwAxPRylKO94FSwJ_oSr5s6fUet0J7xJLLO1N5j6Ft9T ngx4lFu4204q9VWMxoCijkQAvD_BwE
1982 911SC
Old 01-03-2023, 05:08 AM
I've banged and twisted the stupid thing a ton and it's not budging. Might try the hacksaw method. I would hate to damage the clevis itself or the lever to the master cylinder while trying to extract the pin since it seems in perfect shape but it's a $10 part I suppose.
Old 01-03-2023, 11:58 AM
I wouldn't cut it. Silicone spray lubricant (WD40 doesn't count) plus some sort of ball joint separator like I linked (you can get smaller ones) and I bet that sucker will come right out.
1982 911SC
Old 01-03-2023, 12:16 PM
How about freeing up the clevis by removing the rod from the clevis. You may get better range of motion and unbind the pin.
Cut the clevis where the blade meets the base at a right angle.
Old 01-04-2023, 12:05 PM
porschetub's Avatar
Yep the pin is stepped,once out you will most likely need to weld up the slotted hole in the arm ...ask me how I know,cheers.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 01-04-2023, 01:46 PM
i like the ball joint seperator idea if the area is big enough. But with things like this i usually use a good pair of channel locks put a nut over the pin and squeeze like hell. Knipex work well because they get into tighter spaces and seem to have more grab force than the standard channel locks.
Old 01-04-2023, 02:39 PM
