removing and replacing drivers side window lift mechanism om 73 911
From what I gather, the window lift (scissors) unit has a large center spring that adds to the lifting of the window via the hand crank. When cranking up my window, its a struggle so can I assume that the spring no longer functions or is binding? After removing the inner door panel, arm rests and door pockets I am confused as to how to remove the window glass and the entire lift system to replace with a new one.
Can anyone give a step by step procedure for this? Can I just replace the spring unit alone? Thanks Bob 1973.5T |
It is usually the pivot that breaks.
https://www.early911sregistry.org/forums/showthread.php?144123-Help-me-identify-this-piece-of-the-window-regulator&highlight=regulator+spring |
This should help you remove the regulator:
https://www.early911sregistry.org/forums/showthread.php?101491-The-Canary-Drivers-window-removal-felts&highlight=regulator+spring |
| All times are GMT -8. The time now is 04:24 PM. |
