Hazard switch bezel, warning light questions
I have 2 dashboard area problems: (car is a 76 912E)
1. my emergergency/ flasher light switch bezel has broken up and no longer holds the switch in place. I am sure these are nla. Is there a replacement or substitute for this?
2. The lower half of the fasten seat belt warning fixture is dark. Can you just pop this out and change a bulb?
Thanks in advance
Old 01-14-2023, 03:26 PM
Uncertifiable!!!
Uwon's Avatar
Looks to me like our host has them. Search other car years as well. There are lots of parts for the later and earlier years that may do the trick. Also, check classic retrofit web site.
Good luck.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 01-15-2023, 05:14 AM
The Fasten Seat Belt/Brake red display module;
Yes, it simply pops out.
When you say the FSB is dark, do you mean it was “blacked out” by paint or tape or that the bulb is either burned out, removed or not connected and doesn’t light up?
One of the biggest gremlins with the FSB/Brake light is that the switch by the handbrake falls out of adjustment or switch is broken, the annoying Brake dash light stays on all the time and many people just disconnect the dash bulb. Could be the same your FSB light and problem may be the circuit leading to the seat buckle wiring if the light stays on.
Old 01-15-2023, 10:45 AM
