-   -   CIS Return Lines? (http://forums.pelicanparts.com/porsche-911-technical-forum/1133425-cis-return-lines.html)
Stophos 01-22-2023 07:22 AM
CIS Return Lines?
I’m installing an 83 3.0 in a 79 SC and it looks like the return lines have conflicting connections. Can someone confirm that these are indeed the return lines and if so is there a part missing or do I need to replace the line from the engine? Hoping not to go the simple route of cutting the fittings and connecting the lines.
Thanks - Chris
http://forums.pelicanparts.com/uploa...1674400866.jpg
http://forums.pelicanparts.com/uploa...1674400892.jpg
na2ub 01-22-2023 09:57 AM
My 79 CIS had the male cone with nut on the engine side, which screwed on to the female cone chassis side return line. I do believe this configuration changed over the years, so you will likely need some adapter. I can't speak to the 83 CIS, but your 79 should have 3 lines that go through a metal retaining bracket on the driver front of the engine bay. 1 is fuel in, 1 is fuel return, and the big one is the brake booster vacuum line. The fuel in, should terminate in a J bend fitting that goes to the top of the accumulator.
Stophos 01-22-2023 10:27 AM
Missing. It?
If anyone has more info please do post.
Thanks - Chris
Originally Posted by na2ub (Post 11903204)
My 79 CIS had the female cone with nut on the engine side, which screwed on to the male cone chassis side return line. I do believe this configuration changed over the years, so you will likely need some adapter. I can't speak to the 83 CIS, but your 79 should have 3 lines that go through a metal retaining bracket on the driver front of the engine bay. 1 is fuel in, 1 is fuel return, and the big one is the brake booster vacuum line. The fuel in, should terminate in a J bend fitting that goes to the top of the accumulator. The return, in mine, looks as you show it, a male cone.
na2ub 01-22-2023 08:32 PM
I went an checked (and edited my above post). On my 79, the return to tank is a FEMALE cone (M14) fitting. http://forums.pelicanparts.com/uploa...1674448311.jpg
BoxsterGT 01-23-2023 07:30 AM
na2ub-
Actually this is a M14 Male cone.
Male fittings have external threads while Female fittings have internal threads.
Also, I sent a email reply to Stophos.
Len
Stophos 01-26-2023 04:19 PM
Thanks to all that responded and to Len who solved my issue!
