Stophos's Avatar
CIS Return Lines?
I’m installing an 83 3.0 in a 79 SC and it looks like the return lines have conflicting connections. Can someone confirm that these are indeed the return lines and if so is there a part missing or do I need to replace the line from the engine? Hoping not to go the simple route of cutting the fittings and connecting the lines.
Thanks - Chris
Looking for:
1969 911T - Engine - 6196603 & Gearbox - 7196742
1969 911S - 901/13 Gearbox - 7195559
Old 01-22-2023, 07:22 AM
na2ub's Avatar
My 79 CIS had the male cone with nut on the engine side, which screwed on to the female cone chassis side return line. I do believe this configuration changed over the years, so you will likely need some adapter. I can't speak to the 83 CIS, but your 79 should have 3 lines that go through a metal retaining bracket on the driver front of the engine bay. 1 is fuel in, 1 is fuel return, and the big one is the brake booster vacuum line. The fuel in, should terminate in a J bend fitting that goes to the top of the accumulator.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 01-22-2023, 09:57 AM
Stophos's Avatar
Missing. It?
If anyone has more info please do post.
Thanks - Chris
Originally Posted by na2ub View Post
My 79 CIS had the female cone with nut on the engine side, which screwed on to the male cone chassis side return line. I do believe this configuration changed over the years, so you will likely need some adapter. I can't speak to the 83 CIS, but your 79 should have 3 lines that go through a metal retaining bracket on the driver front of the engine bay. 1 is fuel in, 1 is fuel return, and the big one is the brake booster vacuum line. The fuel in, should terminate in a J bend fitting that goes to the top of the accumulator. The return, in mine, looks as you show it, a male cone.
Looking for:
Old 01-22-2023, 10:27 AM
na2ub's Avatar
I went an checked (and edited my above post). On my 79, the return to tank is a FEMALE cone (M14) fitting.
Doug
Old 01-22-2023, 08:32 PM
BoxsterGT's Avatar
Porsche Crest
na2ub-
Actually this is a M14 Male cone.
Male fittings have external threads while Female fittings have internal threads.
Also, I sent a email reply to Stophos.
Len
Old 01-23-2023, 07:30 AM
Stophos's Avatar
Thanks to all that responded and to Len who solved my issue!
Looking for:
Old 01-26-2023, 04:19 PM
