Smile Where to find these?
I'm in the middle of updating and adapting a custom center console. As a result I'm reusing the AC control switches and knobs in the new console. At issue, though is how to give a visual of the knob position?
I ran across this other console and saw some outer rings that were used. It's just the ticket for what I'm trying to solve.
Any ideas of a source for these outer rings with the position designations might be found? (see the yellow arrows that point to the outer rings)
Thanks for all your help!!
Old 02-06-2023, 08:18 AM
Old 02-06-2023, 08:25 AM
There are decals available for guitar and amp knobs to mark positions, probably same for old radios and jukeboxes. That’s where I would try.
Old 02-06-2023, 09:19 AM
PCA Member since 1988
Get one that "goes to 11"!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-06-2023, 09:45 PM
Thanks for the help and the "borderline 11" advice.
Old 02-10-2023, 05:53 PM
