			I'm in the middle of updating and adapting a custom center console. As a result I'm reusing the AC control switches and knobs in the new console. At issue, though is how to give a visual of the knob position?
				I ran across this other console and saw some outer rings that were used. It's just the ticket for what I'm trying to solve. Any ideas of a source for these outer rings with the position designations might be found? (see the yellow arrows that point to the outer rings) Thanks for all your help!!
			There are decals available for guitar and amp knobs to mark positions, probably same for old radios and jukeboxes.  That’s where I would try.
			 PCA Member since 1988
			Get one that "goes to 11"!
	1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall!  |
			Thanks for the help and the "borderline 11" advice.
