-   -   misalignment 915 input shaft? (http://forums.pelicanparts.com/porsche-911-technical-forum/1133607-misalignment-915-input-shaft.html)
alexandervdr 01-25-2023 04:57 AM
I am overhauling the 915 from my non modified matching numbers 1986 3.2 targa
While all the other gears are perfectly aligned (red arrow), there is a 4.5mm overshoot (yellow arrow) of the input shaft pinion against the 1st gear on the gear shaft. This is not a result of my re-assembly skills cause it was there before I worked on it too. I just had not noticed. The wear on the pinion teeth shows that this overshoot remains once the case is back on.
Is this 'normal'?
http://forums.pelicanparts.com/uploa...1674651225.jpg
gled49 01-25-2023 06:50 AM
The offset is normal.
Matt Monson 01-25-2023 07:42 AM
Totally normal.
alexandervdr 01-25-2023 09:21 AM
thanks guys, this is my first 915 tear down, so I lack some confidence hence double check everything ;-)
