misalignment 915 input shaft?
I am overhauling the 915 from my non modified matching numbers 1986 3.2 targa
While all the other gears are perfectly aligned (red arrow), there is a 4.5mm overshoot (yellow arrow) of the input shaft pinion against the 1st gear on the gear shaft. This is not a result of my re-assembly skills cause it was there before I worked on it too. I just had not noticed. The wear on the pinion teeth shows that this overshoot remains once the case is back on.
Is this 'normal'?
Old 01-25-2023, 04:57 AM
The offset is normal.
Old 01-25-2023, 06:50 AM
gearhead
Totally normal.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-25-2023, 07:42 AM
thanks guys, this is my first 915 tear down, so I lack some confidence hence double check everything ;-)
Old 01-25-2023, 09:21 AM
