| Registered |
				SC oil hardline disconnect
			Prepping for an elephant cooler upgrade and spent the evening reading up on breaking the trombone cooler lines loose.  Since air chisels, special wrenches etc are not part of my inventory I'm considering alternatives.  Connections are currently soaking in penetrant and I'll continue reapplying daily I've got a mapp gas torch but not excited about heating connections within inches of original paintwork (I could shield area with a wet cloth) and the dissimilar metal issue also has me concerned. Just fitting any of my wrenches in the tight confines is a challenge, let alone using significant force. Guidance is to hold all components securely while reefing and the idea of managing 2 or 3 wrenches in there gives me a headache. Also the idea of pipe wrenches and extenders makes me pause So my first choice so far is a dremel tool and cut the nuts, spread them apart, and twist them off. Second thought is using a sawzall to cut the tubes near the connections and then using a 20 some MM socket to remove. I'd rather not ruin the trombone but that may happen anyway So what are the recommendations from the happy pelican crew? Nearly 35 years and 215K miles with this jewel. I'm a lucky guy. thanks ahead    | ||
|  01-19-2023, 12:00 PM |
| New-ish 911SC Targa Owner |
			These connections haven't been a problem for me. use the proper 36mm oil line wrench and another suitable wrench to hold the other hex and go for it.   This is the wrench i use: https://www.pelicanparts.com/More_Info/PELPWOLW.htm?pn=PEL-PW-OLW
				__________________ '83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp | ||
|  01-19-2023, 12:26 PM |
| Registered |
			I had to do this and I had to cut the nut even having the correct size wrenches. Just be careful not to cut to far. | ||
|  01-19-2023, 12:31 PM |
| Registered |
			When I removed mine I used a 36mm wrench from northern tool and a big crescent wrench. Came off with no real issue other than some grunting.  Good luck! Sent from my iPhone using Tapatalk
				__________________ 1984 Hellbronze Metallic M491 | ||
|  01-19-2023, 01:05 PM |
| Registered Join Date: Jul 2001 Location: Lawrenceville GA 30045
			You can also pick up a 36mm wrench from a local bike shop/supplier. 36mm is a popular bike headset size. You might need to grind down the sides for clearance - depending on make, etc.
				__________________ Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? | ||
|  01-19-2023, 01:40 PM |
| Registered Join Date: May 2002
			try an induction coil heater?  they work great for no flame heating.
				__________________ Lost 2.7l engine #6141641, drop me a line if you find it.    | ||
|  01-19-2023, 01:42 PM |
| Registered Join Date: Aug 2013
			I used a 36mm crows foot attachment I bought on ebay on the fitting I was loosening and a large adjustable wrench to hold the other line in place. It didn't take too much effort with a long enough lever.
|  01-19-2023, 06:44 PM |
| Registered Join Date: Sep 2001 Location: Columbus, OH
			Agreed.  Remove any brackets holding the lines to the body, to give yourself clearance.  Without the bracket(s) you can flex them away from the body.  I bought a 36 mm from Menards for about $20, and used a previously owned big adjustable wrench to hold the other side.  Even if you buy 2 wrenches, you should be able to get it done for less than $50.  With the proper wrenches, its pretty easy.  I would cut the nuts as a last resort.
				__________________ Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo | ||
|  01-19-2023, 08:59 PM |
| Registered |
			Two honking big adjustable crescent wrenches will do. As others say remove the brackets, that will open up space for you to jam them in there. The oil lines are tough, they won't mind the manhandling.
				__________________ 1982 911SC | ||
|  01-20-2023, 04:01 AM |
| Wildman Emeritus Join Date: Feb 2003 Location: Chitown Burbs
			36 mm wrenches from Harbor Freight for me. Ended up going to my Dremel anyway but as a last resort. If you go this route, be patient and careful.
				__________________ Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold | ||
|  01-20-2023, 05:05 AM |
| Registered |
			Thanks everyone so much for the input.  I'm going to check out some wrenches and see what i can get going.  I'd go straight for the pelican model referenced above but 2 of the 5 customer reviews were negative so I'll do some shopping today and see what comes up.   Input regarding loosening up the mounting brackets for the hoses to improve access is exactly the kind of tip needed. What about loosening up the trombone prior to hose disconnect? Should the trombone be just hanging there connected to the hard lines while I attempt the disconnect? And finally, changed oil about 50 miles ago, at the end of the driving season. Do I need to drain some from the tank or just be prepared when I get the trombone loose, for a quart or so of oil to drain out? My confidence level is improving thanks to all the input. Please keep it coming as I work through this. Pelican rocks | ||
|  01-20-2023, 07:01 AM |
| Registered Join Date: Dec 2014
			Put $20 in the swear jar before you start.
|  01-20-2023, 07:23 AM |
| Registered |
This is fair. Might be worth wrapping your large wrenches in thick tape, too, so they're less likely to break things when you throw them across the garage.
|  01-20-2023, 08:10 AM |
| Registered Join Date: Sep 2007 Location: Boston, MA
				 | Quote:
 The trombone is clamped in place near the bottom. I would leave that and only loosen the clamp after the fittings are disconnected. Mark
				__________________ 1979 911SC Targa | ||
|  01-20-2023, 10:48 AM |
| Registered Join Date: Jan 2006 Location: Clayton NC
			Oil line wrench set. Pelican sells it. I've used mine many times. Narrowed the wrench heads by grinder for better fit in the tight places you mention.
				__________________ gary 70T coupe forever almost done 88 Carrera Targa diamond blue | ||
|  01-20-2023, 11:48 AM |
| Registered Join Date: Apr 2011 Location: Greensboro, NC area
			To augment my strength, I bought two 2 ft X 1-1/2" steel pipes from Home Depot, slipped them over the wrench handles, and was able to easily break the connection.
|  01-20-2023, 12:23 PM |
			Not to beat a dead horse, but sometimes it is helpfull to position the wrenches so the the handles are near each other and apply torque in the correct direction when u squeeze the handles together. Just don’t get your fingers in the middle when it breaks loose.  You can also apply heat to the nut if you are still struggling.
|  01-20-2023, 06:57 PM |
| Registered Join Date: Oct 2001 Location: San Carlos, CA US
			You want to work on an old Porsche 911 oil lines without special tools? Sometimes, it is just better to spend a few bucks on the right tool. In this case the special 36mm wrench designed specifically to get into these hard to reach places is what you will need. Special benefit: you won't need to invent new four letter words.  Buy it.
				__________________ Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 | ||
|  01-21-2023, 05:42 AM |
| Registered Join Date: Oct 2013
			Fleetwood, where are you located. I have the factory oil line wrenches you can borrow if you are in NO CA.
|  01-21-2023, 07:19 AM |
| Registered |
			Ordered the 36mm wrench from Pelican yesterday so will keep penetrating connections.  Also will disconnect hardline mounts and shift connections around for more access.  Please keep the recommendations coming If the loose hardlines give me more access, I may try some mapp gas heat. More details on the heating process would be helpful. Heat, penetrant, cool and then repeat? Like how long should the heat process go? Dissimilar metals and oil in the lines are my initial concerns. Maybe I'll try some shock hits with a hammer if I can figure out a suitable firm foundation Many thanks to all who are assisting. I'm located in Salt Lake City and consulting other friends for specialty tools. One of the treads I've found shows a photo from John Walker with the tools he uses. Very helpful. Dremeling on hold til we try the mechanical disconnect. Starting the search for the 2ft + pipe extenders for the "scissor" type squeeze. My progress is a function of all the great support and assistance . Thanks again | ||
|  01-21-2023, 08:08 AM |
