-   -   More R taillight questions..... (http://forums.pelicanparts.com/porsche-911-technical-forum/113387-more-r-taillight-questions.html)
Joe Bob 06-03-2003 08:06 PM
The fiberglass assemblies showed up with the lenses....but no bulbs....bummer, maybe Manny, Moe and Jack will have some, unless some has an idea. They look to take the double ended bulbs like interior lights....the instructions are in German and Ingo is in Japan still.....
:rolleyes:
http://forums.pelicanparts.com/uploads/911Rasa.jpg
My question is.......
The sequence of lights.....
Starting on the outside top, turn signal yellow, bottom running light.....the single red light towards the middle is the brake light....Right????
john_colasante 06-03-2003 08:18 PM
FUGLY!
Me like.
Joe Bob 06-03-2003 08:20 PM
yup....that's the point. Don't want my ride to look like the guy's next door.....BTW...the pic above is NOT my car....
Jack Olsen 06-03-2003 08:32 PM
You're right about the sequence. Although the running light could be in either position, since both are visible from the side (because of the way the inside one is placed farther back than the outside one).
http://forums.pelicanparts.com/uploads/docked911s.jpg
I went with half-clear on the outside so I'd still have reverse lights. Then I have turn signals above that. I moved a two-light set into the inner red one, so I could have running lights there as well as brake lights.
Joe Bob 06-03-2003 08:48 PM
Thanks Jack.....two multi point questions....8^)
1) Did you get the bulbs seperately? Or did they come with the "kit"?
2) How did you rig the back up light....it looks as if there is only hook ups for three, SINGLE element bulbs. Brake, running and turn....did the original R cars not have back up lights?
Ernie W 06-03-2003 09:01 PM
Typ 911R tail lights
Mike,
The following info is from the Type 911R Driver's Manual (aug. 67). The outside lights (amber, 1 bulb) are the rear turn signal lights. and the inside lights, (red/amber, 2 bulbs) are the tail, (amber half) and stop, (red half) lights. I have posted two photos of R's the first one is the BP Car #1 and the second one is #11, they show the location of the lights. and the bulbs are standard. hope this helps, Ernie Wilberg R-Gruppe #8...http://forums.pelicanparts.com/uploads/R#01-14.jpg http://forums.pelicanparts.com/uploads/R#11.jpg
Ernie W 06-03-2003 09:13 PM
911R photos
http://forums.pelicanparts.com/uploads/BPcar.jpg http://forums.pelicanparts.com/uploads/JScar.jpg
If you would like a photo copy of the Typ 911R wiring diagram i'll send it to you, E.
Jack Olsen 06-03-2003 09:14 PM
Mike, the bulbs came with the Hella assemblies, in my case, or at least the guy who got them for me purchased the bulbs at the same time. I think they're the same as the interior cockpit dome light bulbs. I got three pairs of the light assemblies (including an amber/red pair that I didn't use, so that I could swap the two-bulb innards of the amber/red lights into the solid red pair).
I didn't wire them on my car, though. KevinP73 did (I'm pretty sure). If he reads this, maybe he'll sound in.
Joe Bob 06-03-2003 09:26 PM
Thanks Jack,,,,again.
Ernie....what I have is a half amber/red and a SOLID red....not the solid amber that you have posted in your pic.
Plus it looks like the 1/2-1/2 lens set up is swapped in position from Jack's ride.....
Argggghhhh, so much for authenticity on my backdated SC wannabe clone......
fer 300 bucks you think I coulda got some bulbs.....:rolleyes:
I think I will mount them on the ducktail like a semi trailer.......
Oh yeah....Ernie.....did they have a provision for back up lights or did they do away with them for weight savings....?
dd74 06-03-2003 09:28 PM
How would those look on a middle-year car? Nasty? Not so nasty?
Just wondering...
KevinP73 06-03-2003 09:56 PM
[i]I didn't wire them on my car, though. KevinP73 did (I'm pretty sure). If he reads this, maybe he'll sound in. [/B]
Wiring was pretty straight forward. I salvaged the harness from a couple damaged light buckets I had in the shop. This way removing them for any reason wouldn't pose any difficulties, OEM plugs are still intact. Other than that nothing out of the usual.
Joe Bob 06-04-2003 06:54 AM
Still need a source for the bulbs.....
Jack Olsen 06-04-2003 12:31 PM
Here's a picture of the two bulbs that are in my red running light (upper) brake light (lower) combination.
http://forums.pelicanparts.com/uploads/21Housing.jpg
And here are the bulbs themselves.
http://forums.pelicanparts.com/uploads/21Bulbs.jpg
Big bulb says:
C21W PHILIPS 12V21W 2BR
Little one says:
12866 PHILIPS 12V10W K25673
dd74 06-04-2003 12:34 PM
Is this one of those early car only threads, or did you guys miss my question? :)
Jack Olsen 06-04-2003 12:42 PM
Huh? Did you say something?
Actially, DD74, I saw your car today at TRE. Looks great. Tyson says the thing is surprisingly fast. With the ducktail, I think the R lights would look just fine.
Of course, I'm of the opinion that the R lights are kind of ugly, but very purpose-looking.
dd74 06-04-2003 12:45 PM
Thank you, sir. I'm getting it ready to track with you guys at Willow. Hopefully by Oct. it'll be ready.
speeder 06-04-2003 12:52 PM
I've come to like those lights a lot more than I thought I would on BB2, however I will say that after chasing that car down a dark road or two at speed that the tail lights are pretty worthless as actual lights. Kind of like the token ones on outlaw Harleys down by the rear axles, technically legal but only good for running from the law. Couldn't make out any brake lights, or maybe you never used the brakes(?). ;)
Joe Bob 06-04-2003 01:20 PM
Did not know which year you were refering too....
BTW, found some bulbs, went to Kragen. They are only 10w but may do the trick. Still need to figure the back up light issue. I may just hook up the rear fog light I have laying around.....
PS...thanks for the pics Jack.
andyjboy 06-04-2003 02:36 PM
Mikez, the bulbs you need with contacts on each end as shown in Jack's post above are known as Festoon bulbs. They are available in different wattages (commonly 5W/10W/18W/21W) & varying lengths (commonly 35mm/39mm &42mm).
There are/were a wide range of these Hella lamps available & they're not all the same. Lamps bases were available in metal or plastic construction & designed to accept single or twin bulbs.
The recommended wattage for each particular intended use is stamped or moulded into the inside of the lamp base (see pictures).
The double bulb assemblies for stop/tail or flasher/tail are stamped with recommended wattages of 18W/10W:
http://forums.pelicanparts.com/uploa...ail lampii.jpg
& the correct single bulb assemblies for the all-amber flashers have a recommended wattage of 18W:
http://forums.pelicanparts.com/uploads/flasher.jpg
Andy
'69 911E------------->R
TimT 06-04-2003 02:47 PM
Mike where did you get the lights and mounting plates from?
My 911 is crying for these lights..
