964 3.6L fit to a 915 trans
I am trying to fit a 3.6L 964 engine onto a 915 transmission to ultimately go into a 1978 coupe. The dual mass flywheel and pressure plate do not fit into the 915 bell housing. I'm searching for a flywheel/pressure plate combination that will fit.
Hopefully some folks on the forum have experience or knowledge of this being done. Any comments and/or suggestions are much appreciated. |
Grappler
I believe Patrick Motorsports makes a flywheel combination that solves this problem.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
Racer
What are you using for an ECU? The 964 setup or something aftermarket? I ask because that might change what flywheel you might use.
This setup works well: https://patrickmotorsports.com/collections/flywheel-and-clutch-packages/products/pkg91522536dmespclwpms
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
915 uses a 225mm clutch and matching PP and fw these are not at all compatible most use something like the Patrick conversion fly wheel and a stock sized 915 clutch & pp
I’ve run that Patrick flywheel and Sachs clutch combo on two different 3.6 based motors paired with 915 transmissions. Works perfectly, including holding up to a 370 HP 315 FtLb 3.8. Everything bolts together like its stock.
Slight clearance mod required to 915 bell housing for the 964 Crank Sensor.
1980 911 - Metzger 3.6L 2016 Cayman S |
I'm in contact with Patrick Motorsports.
Thank you all for your input ... much appreciated. |
Racer
The ring gear attaches to the clutch cover…the flywheel doesn’t really have anything to do with ring gear.
