964 3.6L fit to a 915 trans
I am trying to fit a 3.6L 964 engine onto a 915 transmission to ultimately go into a 1978 coupe. The dual mass flywheel and pressure plate do not fit into the 915 bell housing. I'm searching for a flywheel/pressure plate combination that will fit.
Hopefully some folks on the forum have experience or knowledge of this being done.
Any comments and/or suggestions are much appreciated.
Old 02-01-2023, 10:10 AM
Grappler
Rodsrsr's Avatar
I believe Patrick Motorsports makes a flywheel combination that solves this problem.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 02-01-2023, 10:29 AM
Racer
winders's Avatar
What are you using for an ECU? The 964 setup or something aftermarket? I ask because that might change what flywheel you might use.
This setup works well:
https://patrickmotorsports.com/collections/flywheel-and-clutch-packages/products/pkg91522536dmespclwpms
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 02-01-2023, 11:02 AM
Bill Verburg's Avatar
964 uses a 240mm clutch and matching PP and fw
915 uses a 225mm clutch and matching PP and fw
these are not at all compatible
most use something like the Patrick conversion fly wheel and a stock sized 915 clutch & pp
Bill Verburg
Old 02-01-2023, 12:55 PM
I’ve run that Patrick flywheel and Sachs clutch combo on two different 3.6 based motors paired with 915 transmissions. Works perfectly, including holding up to a 370 HP 315 FtLb 3.8. Everything bolts together like its stock.
Old 02-01-2023, 01:11 PM
3rd_gear_Ted's Avatar
+1 on the Patrick MS Flywheel & the Sachs Power Clutch combo
Slight clearance mod required to 915 bell housing for the 964 Crank Sensor.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 02-01-2023, 02:40 PM
I'm in contact with Patrick Motorsports.
Thank you all for your input ... much appreciated.
Old 02-01-2023, 09:08 PM
Racer
winders's Avatar
The ring gear attaches to the clutch cover…the flywheel doesn’t really have anything to do with ring gear.
Scott Winders
PCA GT3 #3
Old 02-02-2023, 09:51 AM
