Cool Anyone else still discovering stuff on their car?
I've had my '82SC Targa since 2012, it's been a blast, and always thrilling for me to learn new things about it. Which I did today...
I'm chasing an electrical issue on my car, and reading my Bentley diagrams today I see a reference to an "Ashtray Light". Hmm, my ashtray never lit up...
I go out to my car, pull the ashtray out of the dash, and son of a gun, there's a rubber-lined hole in the top of the void left in the dash by the now-removed ashtray. I reach under the dash and son of a gun, there's wires leading to the holes. I pull that out and there's a bullet shaped bulb in a socket, same as the ones that illuminate the gauges. This one looked burnt out, I had spares from when I replaced the dash gauges 9 years ago (from eSully for those who know), popped one in, turned on the lights, and what do you know, I've got an ashtray light!
Wondering if anyone else has a similar story?
Thanks, Pelicans!
Old 02-19-2023, 04:42 PM
echecsqueen's Avatar
There is also a light above the glove box that I didn’t know about for years . Hidden unless you are laying on the floor looking up at the box.
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 02-19-2023, 04:45 PM
Engine light for me. I read some where the engine light does not work. And I was like! The engine has a light? I went and checked and there it was
Old 02-19-2023, 07:29 PM
Oh one more. I had the ignition on. And the door open while I was working on swapping out the stereo and I heard a strange buzzing noise as if some relay was messed up. When I drove the car the low pitch buzz went away but a couple of days ago I did the same thing. Car in ignition me in passenger seat and there it was again.
Later I was reading the manual and they said that the car warns if the key is in the ignition and you are exiting the car. I went out and checked expecting some ding ( wish I was sure it was not working for decades and one more thing to fix) and behold. The buzzer.
My millennial a$$ had forgotten how 80s didn’t have an electronic beeper for every thing and the beepers then were relays. And relays buzzed. 😂😂😂
Old 02-19-2023, 07:35 PM
I had mine all apart years ago and thought I found all there is to find. Now I find I'm remembering stuff that I had forgotten when I go back to do maintenance...
Old 02-19-2023, 08:03 PM
Of course you all know the light above the glove box is a three way. ON, OFF, or only ON when the door is open. Great little factoid to re-remember when you're chasing a parasitic battery drain at hi-noon.
Old 02-19-2023, 08:44 PM
It's a 914 ...
stownsen914's Avatar
I discovered a pot pipe under the passenger seat in my first Porsche, a 914. Maybe a year or two after I bought it.
Old 02-19-2023, 09:39 PM
PCA Member since 1988
That's also a good reason to replace all the courtesy lights (and engine bay light for those who have one) with LEDs. I replaced all mine with LEDs, and I left the frunk hood open for two weeks, and forgot the frunk light was on, but the battery still had plenty of charge in it to start the car.
And I'm with Fanaudical on forgetting stuff that I used to know about the car...
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-19-2023, 11:27 PM
gearhead
Only thing I ever discovered in one of mine was an old Kennedy half dollar.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 02-20-2023, 09:17 AM
angelny911's Avatar
1977 targa chasing wiring of all the ad on thru the 80’s cell,phone three different kill switches ,including a Clifford number keypad ,amps ,goose neck equalizer,another red key terminal battery shut off ,and the boy genius who seemed to only owe a rolll of green wire ,,,,LoL
pca 30 year member,1977 porsche turbo body targa
56 vw ragtop oval
01 harley sportster
18 Chevy Colorado diesel
BIG RED Firetruck and assorted v-dub ,porsche parts hoarder..LoL
Old 02-20-2023, 10:00 AM
One of the things most 911 owners never knew is the outside rear view mirrors have heaters to defrost the mirrors in gold weather. Really!
I think they were standard on Carrera models. Just pull the rear window defroster to activate the rear window defogger, the twist the knob to turn the mirror heat on. I have had my 911 for 27 years, and have used the rear view mirror heaters only twice. The fist time was in northern Vermont, when it was just at below freezing and the car was covered in frost in July.
Old 02-20-2023, 02:13 PM
Like others, I had my car for about five years before I realized there was a light just above the glove box. I just happened to have my head down in the passenger footwell for some reason and looked up.
I had no idea any 911s had heated mirrors.
'80 SC Targa
Avondale, Chicago, IL
Old 02-20-2023, 02:41 PM
berndtj's Avatar
I discovered the intermittent wipers like a month ago. I guess I just assumed it would be on the stalk.
I’m still figuring out the HVAC system
Old 02-20-2023, 05:12 PM
Love this thread! I had no idea my car had heated mirrors.. hit the switch and sure enough they work great! Thank you!
87 911 Carrera Coupe
Old 02-20-2023, 05:57 PM
I found the key to understanding it is knowing there's no heat controls in the dash! All the heat is controlled from the seat levers. All the dash does is control where air goes and how fast.
1978 911SC with Lobster Interior - Zoidberg
http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html
Old 02-20-2023, 06:25 PM
I have a Fiat Spider that I’ve had since 1990, and the ventilation controls perpetually baffled me. Then I bought my 911 in 2015 and the day I picked it up, the seller explained the ventilation controls to me. I understood it immediately. Then I realized that my Fiat’s controls worked basically the same way. What took me so long?!?
'80 SC Targa
Old 02-20-2023, 07:40 PM
Someone needs to explain the ventilation / heating/ cooling / defrosting system to me.. i am trying to still figure it out
Old 02-20-2023, 10:22 PM
Enginerd
TxGerman's Avatar
This^^
I had no idea.
Great tip! Thank you for sharing, that gets a gold star!!
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS
Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS
IG: @pcar911fan
Old 02-21-2023, 06:34 AM
Lol, I think I have another electrical issue to chase now. I turned on my lights, pulled the defrost knob, turned the defrost knob to the right…and my gauge lights went out. Assume this is NOT normal behavior…😂
Old 02-21-2023, 07:29 AM
That my car had the alarm system. This was fun to discover at the end of a full respray and engine rebuild when I was finally ready to start the car and the horn started blaring like CRAZY. I had to learn the whole system from scratch only to find out that the body shop forgot to reconnect the door to alarm wire that was tucked behind the dash. Almost impossible to find without knowing where it would be.
Guys the alarm is so loud. I can't stress how loud it is compared to the normal horn. So loud.
That's how you do it??! Now I'm worried. I pulled my mirrors apart for said build and noticed the mirror heat lines were disconnected. I thought everything was cool with them because I turned on the defrost and nothing exploded, but now I don't know....
1982 911SC
Old 02-21-2023, 08:04 AM
