Early 930 slow to start…
3.0 930
Fuel system is rebuilt from electric pumps to injectors and everything in between. Fuel pressures are in spec - system press, WCP, CCP, and residual pressure. SOMETIMES the car doesn’t want to start easily. (6 seconds of cranking and then a puff of smoke on startup) Like I said pressures are good. Volume from the pumps is good. CSV is functioning properly. It has the correct wur and FD. Maybe not fuel related…ignition? What do you think? |
Checked some of the ideas brought up in the thread linked above, no luck.
Bump
| All times are GMT -8. The time now is 02:27 PM. |
