Early 930 slow to start…
3.0 930
Fuel system is rebuilt from electric pumps to injectors and everything in between. Fuel pressures are in spec - system press, WCP, CCP, and residual pressure. SOMETIMES the car doesn’t want to start easily. (6 seconds of cranking and then a puff of smoke on startup) Like I said pressures are good. Volume from the pumps is good. CSV is functioning properly. It has the correct wur and FD. Maybe not fuel related…ignition? What do you think?
it's not leaking....it's just marking it's territory Last edited by Zuffenwerker; 02-18-2023 at 06:19 AM.. |
cycling has-been
73 911T MFI, 76 912E, 77 Turbo Carrera |
Checked some of the ideas brought up in the thread linked above, no luck.
it's not leaking....it's just marking it's territory |
Bump
