r_towle's Avatar
3.0 upgrades
What are the common, tested, and worth the effort upgrades for a 3.0?
Street car.
Larger displacement,
Larger pistons?
Different heads, or ported heads?
Bigger stroke crank?
Etc etc
Old 11-04-2022, 05:39 PM
SSI
M1 cams
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 11-04-2022, 06:29 PM
Old 11-04-2022, 06:31 PM
Jeff Alton's Avatar
Are you looking at taking it apart and upgrading, or is it already apart and needs some attention.
What is your budget? What are your goals for improved performance? How do you use the car?
Cheers
www.turn3autosport.com
Old 11-04-2022, 07:28 PM
What is the weight of your car? year? type of engine as it sits?
What is your driving experience , what is the fastest you have ever driven ?
Do you know what it is like to drift a car?
What horse power to weight ratio do you think makes a car fun to drive ?
Does 230 hp sound like a lot?
Are you changing the brakes ?
Tires, small and fun? or large and super sticky so you will never loose grip?
answering these questions will help you decide
Just my thoughts
Ian
M1 cam and ssi is enough to entertain me , 3.0 cis
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 11-04-2022, 07:53 PM
Bill Verburg's Avatar
Street car.
Larger pistons?
Etc etc
depends on you budget
98mm p/c make a 3.0 a 3.2 you can also add some compression at the same time
74.4mm strock C 3.2 crank makes the ss 3.2 a 3.4
You can add cams but selection there is limited by CIS ability to function w/ more cam
SSI and free flow exhaust is standard first step unless you are going to 3.4 or more in which cast you need the bigger 42 mm versions of SSI
best bang is to toss the 3.0 and put a 993 3.6 in there,
None of this is cheap
Bill Verburg
Old 11-05-2022, 10:41 AM
Reiver
Reiver's Avatar
Euro 3.0 930-10 w SSI's/sports 2 in out muffler.
The real addition was adding lightness by removing 'things' like sound deadening, AC, etc...so at 2300 lbs with prob 220 HP.
That entailed an '83 930-16 to an '83 930-10 engine swap but the rest was 'disassembly'...inexpensive (traded motors) and got what I wanted.
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-05-2022, 11:15 AM
Under the radar
Trackrash's Avatar
Going to carbs, or EFI, better pistons, better cams, and SSIs is the way to wake these motors up.
But in some locations changing the intake or exhaust may cause problems with smog laws.
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-05-2022, 01:24 PM
MichaelSJackson's Avatar
What have you been driving?
Old 11-05-2022, 01:57 PM
Reiver
Reiver's Avatar
True, where I live there are no smog checks and if you have collector auto insurance you get a pass where they have them...Merica!
De Oppresso Liber
Old 11-05-2022, 09:20 PM
I’ve seen the M1 cam pop up here, along with a few other threads as I consider the same subject as the OP.
For those running the M1/SSI combo such as @icarp and @nditiz1:
1) do you have small or large port heads?
2) are you running stock pistons?
3) Is the CIS completely stock?
1966 912, Polo Red w/ Black interior
1980 911 SC, Guards Red w/ Cork interior
1990 Vanagon Westfalia, White w/ Grey interior
2003 Carrera 4s, Silver w/ Black Interior
Old 11-06-2022, 06:01 AM
1980 3.0 small port heads , Cis pistons @ 8.0 to 1 measured , Melissa , M1 or "aka" Kermit cams , all other internals are stock . SSI and Dansk sport muffler . The big change I did was to make an adjustable fuel pressure regulator , this is the key to supplying enough fuel to match the demands, or potential of the camshaft . 230 hp @ crank 2250 lbs makes for a ripping fun car . Others have run this cam with ITB's and it runs even stronger.
Old 11-06-2022, 06:28 AM
Targa_PB_78_SC
mike sampsel's Avatar
Street car.
Larger pistons?
Etc etc
I went with this:
98 mm pistons/cylinders (9.5 CR)
Web Cam 20/21 billets
Active sport cat (Rarly Brian B, alabama boys, "Crotchety Old Bastard" )
The active sport cat is more environmentally friendly and stinks a lot less than the cat bypass I had, it bypasses the mufler on full throttle but not the sport cat. If SSI is better, performance, I would not know. I know the changes I made really perked things up. Pretty sure I went from 180 Hp to ~ 210 Hp (no dyno run though) just my est.
Carbs or EFI and a (20/21 is about as wild as you can go with CIS) wilder cam and headers would be performance additions for me. Doubt I'll ever do any of it though.
BareRearedRookie
Old 11-06-2022, 06:29 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Street car.
Larger pistons?
Etc etc
For what?
Gary R.
Old 11-06-2022, 06:42 AM
Rich,
Just wondering why you're asking about a 3.0? Don't you have an '84 Carrera? Already has EFI and is 3.2. Did you find a good deal you can't resist?
Michael J.
Old 11-06-2022, 07:18 AM
na2ub's Avatar
I am crossing this bridge now. My stock 79 SC is in the process of getting SSIs, dansk sport muffler, and Al's RHD ITB setup.
I considered new pistons with higher compression, and cams, but decided not to get that deep. Maybe down the road.
For now, the upgrades have cost more than I paid originally for the car, in 2000.
Losing weight is not to be overlooked. I would love to get to 10lb/hp for silly fast, but I have certainly shed some weight that the car came with.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 11-06-2022, 10:32 PM
You'll like the setup but if it were me, instead of getting the SSI and muffler up front, I would have gotten cams and compression to make some use of the ITBs.. (assuming you didn't want to spend so much in one go).///later, you could then do the SSI and muffler.
Either, way, you'll still be happy.
Always learning.
www.aircooledporsches.com.au
Old 11-07-2022, 02:36 AM
Free minder
Aurel's Avatar
Street car.
Larger pistons?
Etc etc
Hello neighbor! (I am in Westford, MA)
The mild upgrades I have done to mine while keeping CIS are:
DC15 cams (had my SC cams regrown do by ‘Camgrinder’)
9.3:1 compression pistons (original is 8.5:1)
SSI style HE (from a 74)
Removed a/c, air injectors
Sport dual exhaust (200 bucks on eBay)
I have large port heads already, since it is a 78.
Best,
Aurelien
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 11-07-2022, 03:27 AM
HarryD's Avatar
Street car.
Larger pistons?
Etc etc
Going against the grain here.
Best value for your money?
Tighten up the nut behind the wheel. Attend a bunch of HPDE's and Autocrosses.
Learn to drive the car you got at its limits and then decide if there is any need for mechanical upgrades. You may discover you need nothing more than a second set of wheels and stickier tires.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-07-2022, 11:24 AM
GaryR's Avatar
Which is why I said "For what?".
Gary R.
Old 11-07-2022, 11:27 AM
