Rennch on YouTube
RUSTMAGEDDON - Bringing a 1969 911E Back From The Dead
I thought I’d keep you guys updated on this very rusty chassis project I’ve just taken on. I’m posting all of the videos to my YouTube channel of course, but I’m doing so many chassis reconstruction projects on this thing that I thought it would be worthy to post here as well.
This is a 1969 Porsche 911 E owned by a good friend of mine that has some sentimental value attached to it. He owns a lot of stock 911’s and wants to hot rod this one. It will probably end up with some sort of widebody flares, and a stance similar to my Grey Ghost build. It looked a little rough when I sandblasted it, but then just got worse and worse, as I blasted more Bondo away: ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thankfully, almost every part is available from our host, or restoration design. Gave it a coat of epoxy primer, and got it home on octossorie. ![]() ![]() Sent from my iPhone using Tapatalk
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
![]() Nice, will follow on youtube too, love your fab skills. What's going to be the most challenging part for you, personally?
IG@ADDvanced Youtube@ADDvanced www.gruvdesign.com |
Rennch on YouTube
My first project was to reinforce the chassis since I’d be cutting off a lot of stuff. This will be a continual process of reinforcement as I move through the project.
![]() ![]() ![]() I will be welding in a diagonal as well, but I need to have a bit of space to do the floors first. There are so many things that need to connect to the floors so I thought it would be a good place to start. Yesterday I removed the driver side, outer and inner rocker and started cleaning that area up. Next I’m going to cut the rear of the floor pan out and get the replacement in place so I have some solid structure. ![]() ![]() ![]() ![]() ![]() ![]() After a treatment of rust converter or two, I will POR15 in the inside of this space once I have all the replacement panels handy. Once I get the rear floor in with tech screws or Cleco’s, I will post a video on the Rennch YT channel. (rennch.com/YouTube)
Good skills there Michael.
Behind the Sun
Let me guess.
California car all its life. Never driven in the rain Always garaged Good luck ! |
Rennch on YouTube
I think the thing was just hanging out in 2 feet of water for a couple years. :P
Full Send Society
Ship of Theseus?
My god is your friend lucky to know you. I will eagerly await the new videos; they’re entertaining, informative and well produced.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Rennch on YouTube
That is a huge compliment. Thank you.
Rennch on YouTube
Nice progress today. I’ve got about eight hours into it so far. I completely removed the driver side, inner and outer rocker, and the rear half of the floor pan. The replacement pan I have is not from restoration design… In fact, I have no idea where it’s from and it could use a little bit of help, but it’s nice to see some clean metal on there.
![]() ![]() ![]() ![]() Out with the old, in with the new! ![]() That’s it for now. It needs a ton of fitment work to get anywhere close to being possible but it really is nice to see some fresh metal on there.
Rennch on YouTube
Made some progress on the drivers side rocker and the rear floor in this one.
https://youtu.be/YTta0a0aBEY
PCA Member since 1988
I look at some of the rust bucket projects some of you take on, and I think, "I am not worthy!"
I would just start with a better tub, preferably a unicorn with "no rust." Seriously, I gotta wonder why you would start with this. Is the sentimental value that great?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
I’m curious what the assembled 911 looked like before you uncovered it to expose that rust! I can’t help but wonder if the chassis actually maintained any type of rigidity in a corner.
I look forward to seeing the progress on this….
CURRENT: 2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black 1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue 2024 Macan White, Beige / 2010 Cayenne White, Black PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey |
Rennch on YouTube
It actually looked like a halfway decent car. I blasted so much Bondo off of it.
Rennch on YouTube
These cars are really cool, and they are forever “in style“. Why not bring them back if someone has the means? Sent from my iPhone using Tapatalk
Wildman Emeritus
Michael;
Rough guess how many hours will be in this before it is ready for primer/paint? Hell of a job. Looking forward to seeing it incrementally resurrected.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
Black and Blue
subscribed! thanks for posting...love these type of projects.
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Rennch on YouTube
Not sure. Maybe 250-300?
Rennch on YouTube
You aren't wrong there!
Been here a while
don't forget expanding foam. I had a car that the suspension pan and rockers will filled with expanding foam, covered in bondo and painted by the previous owner. Good thing cars were cheap back then....
looking for 1972 911t motor XR584, S/N 6121622 |
