Know the size of these connectors?
Anyone know the size and if they can be purchased??...rather not BUY and INSTALL a new harness!!..for obvious reasons.
These are the connector ends on the mirror harness, they connect to the interior mirror directional switch located on top of the driver side door garnish.
Old 02-14-2023, 02:02 PM
Hard to tell wire size from looking at the pic.
The terminals or spade connectors are sized accordingly to the wire gauge (mm/awg) and based on the amps the wire will carry as the crimped portion is sized for that size insulated wire.
If you can, get the amp rating for those wires by finding which fuse protects that circuit, also should be indicated on a wiring diagram.
Also, the proper crimper for that type of spade is needed, unless a good solder connection can be made. I never had good luck trying to get good crimps, just too small or odd angle, even with +2 reading glasses.
Old 02-14-2023, 02:22 PM
ROW '78 911 Targa
timmy2's Avatar
.250 or .187
use something to measure the width.
Cycle terminals dot Com carry them .
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-14-2023, 03:11 PM
lake wales fla
Go to PET 1989 911 - 902-52 position #1
111 971 958
I did not check to see if they are available but that’s what you are looking for.
Richard
Old 02-14-2023, 07:46 PM
Comes up FLAT #10
Hi porschyard
I see that 111 971 958 comes up FLAT RECEPTICAL position *10, .not position *1, which of course is the incorrect item.
Am I reading it correctly?...How an I get the correct connector using this site?
Thank for your help.
Old 02-15-2023, 12:48 PM
lake wales fla
Pet
If you go to a PET program like I suggested you will see that Einmalag’s parts diagram is wrong and the # and position I posted are correct.
Pos#1 is 111 971 958 and is the correct number and part you need.
Pos#10 is 111 971 985 and is incorrectly shown on Einmalag’s site.
Richard
Old 02-15-2023, 04:30 PM
https://belmetric.com/electrical/electrical-connectors/non-insulated-connectors/
...buy the correct crimper too, you will then make professional, original looking connections.
Note that if the connector goes in a plug, you need the tab.
D
Old 02-15-2023, 07:18 PM
Thanks Cloggie!
Old 02-17-2023, 11:21 AM
