r_towle's Avatar
Rear trailing arm mount
Does anyone know the correct angle that the torsion bar trailing arm bracket it mounted?
I found that on a VW it’s 15 degrees.
Old 02-18-2023, 04:41 PM
HarryD's Avatar
The angle determines ride height. This tool may be helpful. https://www.elephantracing.com/tech-topics/spring-plate-angle-calculator/
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-18-2023, 04:58 PM
r_towle's Avatar
I may have phrased the question poorly.
The mounts welded onto the torsion tube in the rear that the two banana trailing arms bolt to.
Each arm is bolted with a single bolt.
These are the arms that have the hub and wheel mounted to (and the trailing arm/spring plate)
I am hoping to find an answer to the angle that the brackets are welded on to the torsion tube.
Old 02-18-2023, 05:15 PM
HarryD's Avatar
This picture from a thread by Rothaus (https://forums.pelicanparts.com/porsche-911-technical-forum/1099657-rear-banana-arm-clearance.html) may be helpful.
Harry
2020 MB E350 4Matic
Old 02-18-2023, 05:33 PM
My guess would be 0*. Turbo’s with the short trailing arms says the torsion tube is rotated up 1* I think, not at my manuals now. The pickup points are longer by 50mm as the arms are shorter, so complete different parts there. Non Turbo= Bolt centerline same as torsion tube centerline, 0 degrees.
Old 02-19-2023, 08:29 AM
PRO Motorsports
Tyson Schmidt's Avatar
I think he’s talking about the angle in plan-view.
So at what angle the trailing arm pickup point is mount rearward compared to the sprinplate pivot centerline.
From memory, it’s in the 12 degree range for 911.
Probably in the 16-18 degree range for RSR/930, but that’s just a guess.
Old 02-19-2023, 09:13 AM
r_towle's Avatar
I’m wondering (and planning) to setup the trailing arm on a table to jig this out and find out.
I assumed it would be in a shop manual somewhere but all I found was (I don’t have shop manuals) a picture of how to check that the mounts are not bent.
Old 02-19-2023, 09:40 AM
HarryD's Avatar
What year car?
Please add your car to your signature.
Harry
2020 MB E350 4Matic
Old 02-19-2023, 10:49 AM
r_towle's Avatar
I have too many Porsches
This is a custom project I need to get this angle…
Rich
Old 02-19-2023, 04:01 PM
