-   -   Need help Installing ECU in 1978 911sc (http://forums.pelicanparts.com/porsche-911-technical-forum/1135244-need-help-installing-ecu-1978-911sc.html)
Damon88 02-20-2023 04:51 PM
Purchased a 1983 3.0 engine with a full wiring harness and ECU. I will be installing this in my 1978. ( I could not find a 78/79...) Has anyone done this... Curious where I should be routing the new harness into cab to install ECU under pass seat. Thinking I might have room in rear parking sensor hole through body. Anyone who has had experience with this, could you please let me know.
Cheers
Damon
sigchuck 02-20-2023 05:37 PM
On my 83, the ECU harness passed through a separate hole behind the passenger seat through the back just above the floorboard (probably about where the angle of a rear seat passenger would be) then the bulkhead connector mounted on the engine side shelf near where the cruise control diaphragm is.
You might also consider adapting earlier non-lambda CIS unless you’re confident everything is in working order. There are a few pretty unique electrical parts for the lambda cars that I don’t think have a lot of aftermarket support. I think you’d just need the fuel related parts and hoses, but I suspect someone else in here has done the same previously. The engine chassis harness should have all the right connectors for the CIS components not related to the lambda system (the lambda related parts are all on the lambda harness that runs from the ECU).
Damon88 02-20-2023 05:56 PM
Thanks Sigchuck. I will look around that area and see if I can find a way through.. All CIS/Lambda parts were rebuilt along with entire engine. Everything has been tested and working perfectly ... ..fingers crossed hah.
Cheers
john walker's workshop 02-20-2023 06:01 PM
If you use the 78 fuel distributor and warmup regulator, you won't need that stuff.
Dr J 02-20-2023 06:10 PM
I did it. You can see my install here:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/960640-another-aem-efi-conversion.html
The ECU cables went through a hole I drilled with an appropriate grommet on the rear passenger side vertical wall about 5 inches from the shifter tunnel tunnel and about 2 inches from the floor (going off memory). I can check and provide more accurate details, if needed.
Damon88 02-20-2023 06:28 PM
Thank you John! I'm going to try and get this set up running. If all else fails I will go this route. Appreciate you responding.
Cheers
Damon88 02-20-2023 06:30 PM
Thanks Dr J, Great information. I will check it out.
boyt911sc 02-21-2023 04:13 AM
Damon,
Aside from the ECU and main wire harness, do you have the enrichment wire harness and relay? You need all these plus OXS.
Tony
Damon88 02-21-2023 05:50 AM
Originally Posted by boyt911sc (Post 11929023)
Damon,
Tony
Hi Tony. Engine arrives today. this is one of the pictures of the harness and ecu. OXS is in with engine. Cheers
http://forums.pelicanparts.com/uploa...1676991035.jpg
