-   -   MFI crossbar return spring (http://forums.pelicanparts.com/porsche-911-technical-forum/1135601-mfi-crossbar-return-spring.html)
chauser 02-26-2023 10:57 AM
Hi
My crossbar return spring appears to have slipped (arrow), I think it should be on top (star).
Someone previously also repositioned the pivot point of the spring - not sure why (pict2)
I'd like to either replace, or reposition the current spring, as my idle is not returning to set point always.
In either case I'm not sure how to approach that - lots of spring tension!
Suggestions for repositioning or replacing with new?
http://forums.pelicanparts.com/uploa...1677437609.jpg
http://forums.pelicanparts.com/uploa...1677437634.jpg
RSTarga 02-26-2023 04:51 PM
edit: is the other end inserted into the the hole
chauser 02-26-2023 05:29 PM
No, the pivot end can be seen in 2nd picture by the large washer
chauser 02-26-2023 05:30 PM
In general, how do you wind spring up say 1 more turn?
