Distributor cleaning question...
1986 Coupe here...
Had some oil leak problems that have been addressed and PO replaced items, but maybe not as thoroughly has they could/should have been. So this is what I am working on this morning: ![]() I found one thread: Distributor Lube/Clean for '88?? So I ordered a new dust cover, new cap, new rotor but really want to clean this up before putting back together. I will in the future remove everything for a very thorough cleaning but time and events coming up I just want to verify per the thread I linked to if brake cleaner and blowing out with dry compressed air is okay for just this portion of the distributor??? As, always can't thank you all enough for your input. Erik
1986 911 Coupe 1986 911 Targa |
PCA Member since 1988
I assume you have removed the distributor? A quick and dirty job is to spray it with solvent, brush it, and blow it out. But it's not hard to disassemble it. Then you can really get it clean, re-lubed, and check for wear; instead of putting it off to "the future."
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Just finished many many other small projects and want to clean this up and start on the valve adjustment and fuel pump replacement. This summer the engine gets dropped (my first time) and I will addressing the leaks and cleaning then... My concern is sometimes I feel brake cleaner is almost too harsh... Thanks! Erik
Well, if you are not removing the distributor, and it's working, don't mess with it now. You could end up causing more problems. put a couple drops of oil on the felt and close it up. "If it ain't broke, don't fix it!"
Another question:
Do some use Permatex/RTV on the body to dust cover to create a seal? As I clean I am scraping off RTV or the likes.
...And a follow up: Why drop the engine this summer? You should be driving the car in the summer! Wait until winter.
No sealant on the distributor cover. By the way, that's not really a dust cover, it's a shield intended to cut down on electrical noise and potential interference. THat's why is has a graphite look to it.
Indeed! BUT.....south Texas here so the summers are a bit harsh on the car...and myself. AC delete and I am a windows down kinda driver - I don't mind sweating a bit on the 95/100 degree days but the temp gauge shows the car doesn't like it Quote:
Again, thanks! Erik
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
For right now I am tracing down leaks, replacing the Frankenstein harness/wiring from the previous owner and just enjoying the spring temps and driving. Have the Hill Country Rally coming up and some other events...not dropping the engine until July-ish... Have a good one! Erik
3.4 Bigger is better
Here is what I did with mine awhile ago. Might help.
Carrera Distributor taking apart and reassembly
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Excellent! Many thanks...will be doing that this summer.
