Kind of Blue
Failing ignition switch?
Ever since I bought my car, on rare occasions, turning the key primes the pump but the car simply will not turn over. Usually, 3 - 4 tries and it eventually starts. It hasn't done this in well over a year but I just went out for gas and it decided it did not want to turn the engine over after refueling.
I gave it 6 - 7 tries then it started like normal. Is it safe to assume the ignition switch is dying?
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Kind of Blue
Of course, I get home and test it and it’s working fine. Old cars are fun.
I'm far from an expert but I'd like to suggest you check for an iffy wire connection at the ignition switch OR at the soleniod at the starter.
Do you hear a click (at the starter) when you turn the key to start? Could be a bad ground. Check (clean) the trans, to body ground strap.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Kind of Blue
A bad ground like the tranny strap would make sense too.
do you have any alarm in your system?
Ivan
1985 911 with original 501 587 miles...807 226 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Mine did the same, starter ground cable corroded. That will cause a zero cranking condition, so will an equally bad negative battery cable or terminal connection and affect charging.
Kind of Blue
Nope.
I'll try and find the starter ground cable. The battery cables are relatively new. Thanks!
PCA Member since 1988
Among the other possibilities discussed, this symptom is fairly typical of a starter wearing out. Do you have any idea how old the starter is? But try the easy/cheap stuff first.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
One way to check if ignition switch is the culprit is to have heater, fresh air, and/or AC running when you try to crank and get zero response.
If car engine does not start (no crank at all) but the heater/fresh air/AC stops running while key is in crank position, that means ignition switch is good and you can go on with other possible reasons discussed above. |
Kind of Blue
So when in the crank position, my ECU emits a "beeeeeep" prior to starting and it persisted while refusing to crank. My issue is that I may not be able to reproduce the problem for another year!
Kind of Blue
The more I think about it, the more I'm wondering if the starter is the culprit. I've noted that when it's cold, it sometimes seems like it cranks a hair slow. Battery is new and voltage is fine, so a failing starter would make sense.
I pulled off the key bezel and the entire ignition unit was removed previously at some point as I didn't have the two bolts that have to be sheared off to remove it installed, so it's likely the switch was replaced at some point, most likely in the '90s when the car was refurbished.
main culprit is most of the time the ground cable from transmission to the body....
Ivan
Kind of Blue
Well, I took it for a spin and she started on the first turn like she has done every time I've driven it for the past 18 or so months.
We'll leave it at "keep an eye on it" for now. I need to throw her on my brother's lift and grease the spherical bushings in the next month so I'll check the tranny ground strap then.
Yeah, keep an eye on it. What happens as the starter wears is the brushes wear down to the point where they are barely making contact with the commutator. Then it will occasionally not start. IF you bang on the starter with a hammer or rock or such, it will then start. That's pretty much a dispositive test for a bad starter. Then it gets more frequent until you get tired of messing with it and replace it. Or you can take matters into your own hands (pun intended) and replace the brushes and get many more years of use out of the starter.
Rebuilding a starter consists of disassembly, turning the commutator to ensure it's smooth and relieving the insulation between the commutator poles, cleaning and re-lubing the bearings, and installing new brushes. You may also replace the pinion gear/engagement clutch part on the nose of the starter. Good for another 5000 or so starts.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 03-05-2023 at 02:20 PM.. |
So, my advice is change the solenoid (cheap and effective solution) or buy a new starter which of course comes with a new solenoid (more expensive solution). But do this only after you have checked all the grounds. Roy
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
kinda slow
I went through this and did every single suggestion suggested above. I drove myself crazy and replaced nearly every part imaginable chasing it down. Same exact symptoms you describe (video!). Finally I found this thread...
Ignition switch - inside to fix START lockout It may not be your fix, but wanted to throw it out there in case you end up chasing this for years like I did.
1983 911 SC Coupe |
I can agree with JSV798 and PeteKz…as contacts do get corroded just from no use and by repeated arc that occurs upon starting. There’s still the issue that no current is getting to the starter which of course could be from the ign switch.
I can’t recall which (analog) car I had years ago, but being short on funds for a new starter I would crawl and reach under and give the starter a whack with a hammer. The solenoid was attached to the starter but couldn’t access it directly but hitttng the starter was enough to get the solenoid to do its job. Fords used to have a remote solenoid on the fender wall, when they had starter issues you could hear the motor whine if the solenoid wouldn’t engage. |
Kind of Blue
So, naturally, I cannot reproduce the problem.
I really want to take the 2 hour ride to Carlisle in it this year but really don't want to end up being bump started 100 miles from home!
