Need a diameter spec
Yes, I did search.... 356 pages of sorting through to find the "maybe it's there" answer...
Does anyone happen to know what the inside diameter of the receiver of a shift knob should be to fit to an original 915 shift lever using an oem (99953200300 or 01) crush sleeve? I measured my shift lever at 15.04 mm (0.593") dia., but I haven't found the "thickness" of the sleeve itself, and dont have one on hand to measure. TIA |
if you squeeze it it has 15,70mm.part number
999 532 003 00http://forums.pelicanparts.com/uploa...1678004465.jpg |
Thank you Ivan.
To confirm, when the sleeve gap is closed you measure 15.7mm? So I should be looking at a knob bore of <16.0mm, mas o menos? Cheers |
yup when is closed
Ivan |
| All times are GMT -8. The time now is 10:03 AM. |
