917_Langheck's Avatar
Need a diameter spec
Yes, I did search.... 356 pages of sorting through to find the "maybe it's there" answer...
Does anyone happen to know what the inside diameter of the receiver of a shift knob should be to fit to an original 915 shift lever using an oem (99953200300 or 01) crush sleeve? I measured my shift lever at 15.04 mm (0.593") dia., but I haven't found the "thickness" of the sleeve itself, and dont have one on hand to measure.
TIA
____________________________
If it's not leaking, it's out of oel...
Old 03-04-2023, 05:33 PM
proporsche's Avatar
if you squeeze it it has 15,70mm.part number
999 532 003 00
1985 911 with original 502 191 miles...808 198 km
Old 03-05-2023, 12:23 AM
Thank you Ivan.
To confirm, when the sleeve gap is closed you measure 15.7mm?
So I should be looking at a knob bore of <16.0mm, mas o menos?
Cheers
Old 03-05-2023, 10:49 AM
proporsche's Avatar
yup when is closed
Ivan
Old 03-05-2023, 10:59 AM
