Broken tabs on rear sway bar mount
Brought my car up because occasionally hear a faint clunk in the suspension and last time this happened it was a loose sway bar bolt. Sway bar bolts aren’t loose but I did find that the little tabs on the inside of my sway bar mount seem to have separated. The other side isn’t like this - and I have a mig welder - so I can probably make short work of this - just wanted to see if this was a common issue.
http://forums.pelicanparts.com/uploa...1678509924.jpg |
Not common on an 86, but more on the older chassis.
Elephant racing makes an upgraded mount. Might be worth welding in “while you are in there”
That said - I’ve been reading where those solid mounts put more strain on the chassis. Nice thing about the non solid mounts is that they have a little flex to them which - for a street car - seems like the right move. I would feel better about those solid mounts if they were engineered with a little more surface area to weld to the chassis to spread out the load. |
My 88 Coupe were broken upon receiving the car. Grab the welder and fixed the issue.
http://forums.pelicanparts.com/uploa...1678566316.jpg http://forums.pelicanparts.com/uploa...1678566316.jpg |
Wevo makes nice swaybar mounts , after repairing / welding mine twice on my 89 i went all out and welded in new units.
| All times are GMT -8. The time now is 07:01 PM. |
