Send a message via Skype™ to kyngfish
Broken tabs on rear sway bar mount
Brought my car up because occasionally hear a faint clunk in the suspension and last time this happened it was a loose sway bar bolt. Sway bar bolts aren’t loose but I did find that the little tabs on the inside of my sway bar mount seem to have separated. The other side isn’t like this - and I have a mig welder - so I can probably make short work of this - just wanted to see if this was a common issue.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250
Old 03-10-2023, 08:46 PM
Better crop
Old 03-10-2023, 08:48 PM
Not common on an 86, but more on the older chassis.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-11-2023, 03:13 AM
Elephant racing makes an upgraded mount. Might be worth welding in “while you are in there”
Old 03-11-2023, 05:05 AM
Thought about it - but this is a 1-2 hour welding job tops and that includes getting the car up and removing the sway bar and bushings - cleaning up - painting etc. putting entirely new mounts on there is a different undertaking. Might do it when the engine is out sometime next year though.
That said - I’ve been reading where those solid mounts put more strain on the chassis. Nice thing about the non solid mounts is that they have a little flex to them which - for a street car - seems like the right move.
I would feel better about those solid mounts if they were engineered with a little more surface area to weld to the chassis to spread out the load.
Old 03-11-2023, 10:05 AM
I'm good with tools.
AG81's Avatar
My 88 Coupe were broken upon receiving the car. Grab the welder and fixed the issue.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 03-11-2023, 12:26 PM
Northern Motorhead
wildcat077's Avatar
Wevo makes nice swaybar mounts , after repairing / welding mine twice on my 89 i went all out and welded in new units.
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 03-11-2023, 12:54 PM
