berndtj's Avatar
Originally Posted by mikedsilva View Post
sorry, didnt realise it was shared to a private group..
Try this?
https://www.facebook.com/marketplace/item/981659593212921
I'm in the USA and certainly interested . Should I message through FB, or here?
Old 03-16-2023, 03:09 PM
Mark Salvetti's Avatar
Originally Posted by Ctopher View Post
I have the Rennline mount but replaced the magnet base which wasn’t that strong, with an Amazon misc wireless mount. It has a better magnet and it just snaps onto the same ball, most are probably interchangeable, and cheaper than buying their new wireless option.
Yeah, I just bought this and it snapped onto the ball of a different mount. Using it in my Mazda, but planning to use it with the Rennline mount as well (although at the moment I don't have a Rennline to test with).
Syncwire Mag Charger
Mark
1979 911SC Targa
Old 03-16-2023, 08:36 PM
I have the rent line mount in my 71 and it keep bumping the phone off of it when I shift or turn the wheel it’s honestly awful
1971 911T British Racing Green 3.2L
2013 981 Boxster S Aqua Blue/Grey
2014 981 Cayman S Agate Grey/Black
enjoyed and passed along:
1990 964 C2, 2007 C4S Cabriolet, 1997 986, 1958 356 A
Old 03-16-2023, 10:57 PM
I've positioned my rennline mont so that the magnet's at the 2'oclock position (facing up and to the right), in this position, my phone's nowhere near my steering wheel or shifter.
Old 03-17-2023, 07:14 AM
Same. So far, I hate it, but I am going to keep trying it to see if I can get some muscle memory to work around it.
'81 911 SC
'03 BMW M3 (Sold)
'64 VW Beetle, 2332, 48 IDA (Sold)
Instagram: @j_smallwood
Old 03-17-2023, 07:17 AM
Curious about this. Can you share a photo?
'81 911 SC
'03 BMW M3 (Sold)
Old 03-17-2023, 07:18 AM
Porsche Owner
mark4ton's Avatar
i ended up using a rennline mount, but instead of the magnet attachment, i had a samsung suction mount that grabs the phone, i took the magnet mount off of the rennline and attached that grab holder. now i dont have to worry about the magnet not holding. i also ran a cable to it so i can charge and listen to my phone on through the car.
1987 Carrera - 2008 Cayenne Turbo
Old 03-17-2023, 09:12 AM
yeah plus one, I have in the standard position and it's so bad I've stopped using it, haven't gotten around to taking it out. The car is in a Car Capsule for the winter right now so I can't check to see if I can rotate but mines here, and this sucks (Image not of my car, found it on the web)
Old 03-17-2023, 09:21 AM
Yours looks weird. Mine is down at like 4 o'clock and there's tons of room? It's nowhere near the wheel or shifter.
1978 911SC with Lobster Interior - Zoidberg
http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html
Old 03-18-2023, 03:05 PM
Happy to do so, but away from my Carrera for the next week. FWIW, the photos that jrwilson and gremlin posted both appear to show their rennline mounts fitted so the magnet is at the 4'oclock position -- mine's positioned/rotated so that the magnet sits directly out from the minute hand in gremlin's post, which allows my phone to sit a fair bit higher up and closer to my field of vision than gremlin's phone is in the picture.
Old 03-19-2023, 05:35 AM
Mine orients like the others, around 4:00 mark, but admittedly, my phone rests on the magnet near the top of the phone since I have a pop socket on it. Removing the pop socket would allow it to rest a little higher, but I would hate to give up the pop socket, and I don’t think a single inch higher would make that much difference in giving clearance for the shifting problem. My hand is back and forth from the steering wheel to the shifter a billion times per drive and, inevitably, the phone is in the way on one of those trips and ends up in the floor board. 🥴
I’d love to see a pic of how yours is oriented.
Old 03-19-2023, 06:39 AM
Will do -- FWIW (and now that I think about it a bit more), my '86 targa has a factory short shift, which may also be helping reduce the potential interference between my phone and hand while shifting.
Old 03-19-2023, 06:49 AM
Kraftwerk's Avatar
Porsche was so ahead of their time they have a smart-phone holder built right into all the '74 thru late 80s cars: the ash tray ! I just open the ash tray and put the iphone horizontally in - the ashtray holds the phone to the lower-dash .. it works okay actually. For a more 'heads-up' display nothing beast a windshield-mounted suction-cup deal, the better ones work fine, I use that method on the Miata...
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 03-19-2023, 10:31 AM
famoroso's Avatar
I've had zero interference issues with my Rennline clock mount cellphone holder. That's with an extended hub 380mm steering wheel, stock height G50 shift lever and a large phone (S22 Ultra). I have two cases; 1) an everyday silicon case that I'll sandwich a loose rectangular metal plate between the phone and the inner case and 2) a travel hard plastic case with a round metal plate adhered to the outside of the case. I can place the silicon version higher on the mount and it will occasionally shift on the mount after a reasonably hard impact. The plastic case with the external metal plate doesn't move, in fact, I can rotate the phone 90 degrees to landscape and it still stays put.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 03-19-2023, 11:55 AM
Ctopher's Avatar
I found this the issue with then original magnet on the rennline mount. That is why I bought a aftermarket along with option for wireless. The aftermarket has a much stronger magnet that keeps the phone attached even if you bump it.
CTopher
Old 03-19-2023, 04:38 PM
Mob Armor makes a magnetic holder that works well if you have metal or thinly covered metal to attach to, like the longhood A-pillar. One version has a magnetic mount also on the phone side for your case -- unless you use wireless charging.
A second version has a cradle for the phone. The base magnet is very strong, but you have to find the right spot for mounting.
I haven't had it on many drives yet, but figured it's worth trying.
https://www.amazon.com/gp/product/B08Y616KWX
https://www.amazon.com/gp/product/B01BINVA88
Old 03-19-2023, 04:59 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Got it today,
Looks well made. A bit of a design flaw in that they provide an Alan key that only fits one of two screws. Why not make it with the same size screws for both? Hopefully I have the right size key to tighten the nut that attaches it to the clock.
Edit. I installed it. Fits well and holds the phone solid. You need a weird hex or star wrench to tighten it around the clock. Why would they not provide this or make the screw the same size as the other one? I had the right size tool but I bet most would not as its very unusual.
Chris
Old 03-20-2023, 05:50 AM
Danimal16's Avatar
My Rennline works great. I did have to wrap the gauge with tape to make the gasket fit tight. That was the only issue, now resolved.
I have a question for others, has anyone found a phone cradle, to replace the magnet that fits on the Rennline ball for an iPhone 14?
Dan
Old 03-23-2023, 11:03 AM
This is a smart solution for G model
Old 03-28-2023, 02:29 AM
Rennline update: So, I added a metal backing plate to the bottom of my phone and tried that this weekend. This works MUCH better and I didn't have any hand collisions with this location. It did require some infrequent adjustment as the bumps would cause it to twist a bit. I can deal with that.
'81 911 SC
'03 BMW M3 (Sold)
Old 03-28-2023, 05:49 AM
