Porsche 911 3.2l 1984, ECU
3.2 ECU function. Does anyone know what pin 4 on the ECU does. It is connected to the starter motor, yellow, switch.
The Bentley says it is "battery voltage in start position".
Checking the ECU internal schematic, it is indeed a battery + that controls an internal transistor that in turn provides a temporary ground to the DME relay (so the fuel pump can run right from start) before the ECU "decides" it is good to go and provides its own internal + to the same transistor, so that the DME relay stays grounded once the ignition key is released (and therefore the fuel pump keeps running). That's a complicated explanation, but that's what it appears to be. Last edited by wazzz; 03-07-2023 at 04:16 AM.. Reason: typos |
It's used to tell the DME to turn on the fuel pump. Internally there is an OR function that controls the fuel pump logic: If this pin is powered OR if flywheel rotation > 200 RPM is detected by both FW sensors the 2nd stage of the DME relay is turned on and delivers power to the fuel pump and the O2 heater.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
| Tags |
| ecu , starting |
