'82 SC TL
Here's a couple of pictures of red, old stock Purolator filters for Porsche (literally stamped on boxes they're packaged in), made in Germany (marked on actual filter) I bought (hopefully the pics showed up?)
76'S 1st Porsche white/can/can early rebuild (boo) ![]() '84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1) ![]() '87 Carrera cpe white/blue short flirt ![]() '89 Anniv. sil/linen very pretty miss her ![]() '88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Canamfan, I'd compare the combined area of the holes to understand the difference. If you get qty and diameter of each hole you can understand the difference in flow capability.
Don't forget to factor in spring rate to calculate bypass ratio. If more holes = more flow (in this exercise}, but bypass spring is lower than the other canister, then filtering means little at high (above spring rate) pressure and the number of holes isn't a concern.
'82 SC TL
Purolator PC260 (old stock made in Germany) on left & Mahle OC54 (made in Austria) on the right, I’m no expert, but these look identical other than pinch marks on Mahle, hope they’re really just as good as each other, but I don’t know what to look for exactly
[/QUOTE]and where did you find it? Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
'82 SC TL
Had bought the Mahle (4 or 5 of them) a couple of years ago from Worldpac & Autocamping (all of them were either from Germany or Austria), the Purolators (4 of them off eBay recently), down to my last Mahle though & my recent purchase from Worldpac has sent me a “made in China” Mahle (probably won’t be using it), hence the recent Purolator purchase
Be careful with these NOS Purolator filters. I picked up a few on EBay and was excited because I thought I would be good to go with Quality filters for the foreseeable future. However, I was concerned when mine came today and I noticed some light rust on the threads. I felt like there might be more rust lurking inside, so I sacrificed one and cut it open. Sure enough there was more rust. At this point I’m afraid to use any of them. :-( ![]() ![]()
Just buy Mann filters they are still high quality
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Still here
Which ebay seller was it ?
Still here
![]() Are we back to the original filter or has PP not updated the pics ? |
So our options are..
Germany.. Mann W94029 - $12 Porsche/Purolator - $18 Chyyyna... Mahle - $9 'Murica Baldwin BT292 $19
1987 Porsche Carrera Coupe |
Mann produces a lot of different oil filters at a plant in NC. Not sure if this one is produced there. I have always liked their products. I use to go through the factory for work a lot.
I have been using the Baldwin filters on my 911 as well as my 86 El Camino. Of course totally different filters, just the same brand. I have cut open several of the used filers and they seem to be very high quality.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Nice, where do you buy them?
Here's another option:
Donaldson P552819 - $12 Country of Origin Mexico Efficiency 50% - 20 micron https://cdn.shopify.com/s/files/1/0592/2648/8986/files/P552819_Donaldson_Details.pdf
Amazon. And buy several at a time so they pack them in a box, and not in a bag so they don't arrive dented and have to be returned.
Banned
Cut it up.
