-   -   Can't get motor separated from trans (http://forums.pelicanparts.com/porsche-911-technical-forum/1136705-cant-get-motor-separated-trans.html)
almostordinary 03-18-2023 07:36 AM
Hey gang.
A little stuck on a weekend project, can't separate a fellow pelican's engine from the trans.
Looks like we need to remove the clutch adjusting arm, but it's seized.
Came to visit a buddy this weekend for a quick refresh but now we're a bit stuck.
Is there any tool we can snag from Oreilly's that will make quick work of this?
http://forums.pelicanparts.com/uploa...1679149910.jpg
We've done a couple of propane heat cycles and hammer hits, but hoping to persuade this off with a more tactful approach.
I've included a picture of my pups that are driving my wife crazy at home right now to expedite some insight from folks that have been stuck here.... she needs me back :)
http://forums.pelicanparts.com/uploa...1679150068.jpg
Thank you!
Tyson Schmidt 03-18-2023 08:07 AM
You have to remove the clutch lever arm first.
The clutch fork indexes into the T.O. Bearing, since it’s a pull clutch.
Remove the snap ring from the small arm and remove it.
Then pivot the omega spring and long arm to release the spring tension and then it will come right off.
Edit: sorry, I missed the part where you said it was seized.
Is it the smal arm or long arm that is seized?
Funracer 03-18-2023 08:10 AM
http://forums.pelicanparts.com/uploa...1679151931.jpg
This worked nicely. Some type of puller I had in the drawer. Cannot ever have too many tools!
Tyson Schmidt 03-18-2023 08:36 AM
Nice.
Yeah that clutch fork shaft looks pretty rusty.
I’ve never had the small arm seize, but I’ve seen the omega spring arm seize on many times.
Glad you got it handled.
