911 speedo in a 930
Hi,
I wonder if a 911 SC speedometer will work correct in a 911 Turbo (930) ?
Cheers
Old 03-27-2023, 04:00 PM
Walt Fricke's Avatar
Should work. In 1976 the 911 shifted from a cable speedometer to an electronic speedometer. Seems the Turbo had that from the get-go. But you might need to have it "tuned." The speedo has to be matched with the tire circumference. Some SC speedos only go to 85mph!
Old 03-27-2023, 04:18 PM
As Walt says, all the electronic speedometers interchange, up to the G50 - they all use a reed switch with a disc of magnets (8, I think) in the transmission to drive the speedo. It just generates an analog square wave signal that the speedo "counts".
I thought the changeover to electronic was earlier than '76 - but some show still listed in 1976 for base (eg non-S, non-Carrera) 911s. Heh. Those have gotta be pretty rare...
I've had the original, 930 & 3.2 speedos in my '77, and am currently driving mine from a G50.
They Just Work - however, calibration is a real issue, if not running the exact wheel size & tire profile (and hence rolling diameter) speedo was originally designed for. You can end up 11-15% out, or even more. Mine were useless with low-profile 17" tires...
I fitted a Yellow Dog in 2012 and keep forgetting it's there... Calibrate until it's as accurate as you need (I prefer mine to show the "real" speed) and forget it.
https://forums.pelicanparts.com/porsche-911-technical-forum/951077-speedometer-correction.html
'77 S with '78 930 power and a few other things.
Old 03-28-2023, 03:46 PM
Right - it is 8 magnets, glued radially in an aluminum disk.
What sends a signal to a G50 era speedometer?
Old 03-28-2023, 04:25 PM
The same arrangement, at least for G50's from G-body cars - '89 parts drawing 3-05 (305-00) part #15:
So the factory didn't need to change speedometers for either the 911 or the 930 when they went G50.
Old 03-29-2023, 09:30 AM
