jwakil's Avatar
Best brake bleeder
I’ve always preferred the vacuum type brake bleeders because I felt with our old cars it wasn’t safe to pressurize a 40year old master cylinder reservoir. However, what I’ve found when I apply vacuum to a brake bleed nipple is that I can’t tell if I’m drawing air bubbles from inside the brake system or the air is coming from the threads of the nipple that I’ve just loosened. I continuously see bubbles even though I know their is no air in the system. Would like to know what most people use and if the pressure method is ok to use on these old cars. Of course the two person method is always best but I’m looking for the one man bleed methods.
Old 01-27-2023, 05:37 AM
I have had the same problem with vacuum bleeders. I've tried thread sealant and "speed bleeders" and haven't found those useful either. I've not found the vacuum bleeders to work well on my 911 at all.
I had the same concerns about the old reservoir on my car; I replaced it with new and went the pressure bleed route. Even then I had to have somebody pump the pedal and few times to be absolutely sure I had the air out.
Old 01-27-2023, 05:51 AM
Home of the Whopper
Used this one on MANY different cars over MANY years:
(not the reservoir, but the fitting and tubing)
Discussion thread:
https://forums.pelicanparts.com/porsche-911-technical-forum/427910-5-pressure-bleeder.html
1968 912 coupe
1971 911E Targa rustbucket
1972 914 1.7
1987 924S
Old 01-27-2023, 06:10 AM
Original Owner
tsuter's Avatar
All you need is a Motive power bleeder, assortment of silicone tube sizes for your calipers, a turkey baster, some nice ATE DOT4TYP200 and a brake fluid moisture tester.
Oh, and if you think your master cylinder can't handle 10-12psi, then your car is unsafe to drive...
And don't forget to unhook your brake fluid master cylinder overfill drain hose and put a nice piece of silicone tubing on that and clamp it off.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 01-27-2023, 06:44 AM
7783911's Avatar
which model of Motive is suited for our porsches
Old 01-27-2023, 07:08 AM
Cory M's Avatar
+1 for Motive. I've used mine on several different cars over many years.
Old 01-27-2023, 09:54 AM
Usually what I use is a vacuum bleeder until I get to new fluid (it will move pretty quickly once it's going) then do a final pump from the car through the speed bleeder or with an assistant. Like you said, the vacuum bleeder can be misleading with the air bubbles so it's better to finish off with a pressurized pump from the master.
I have a motive that I use for other cars but I just don't quite trust it on the 911, especially with that overflow. Plus I haven't tapped an air fitting to it yet and it takes about 9,000 pumps to get up to pressure.
1982 911SC
Old 01-27-2023, 12:01 PM
Discussion thread:
I have the motive, but I'm embarrassed to say I didn't think of this as the best way to hook it up. Looking at this, there was no reason to buy the special cap, should have just hooked the damn thing to the bleeder port instead of trying to block the bleeder... this is much smarter.
Old 01-27-2023, 12:15 PM
HarryD's Avatar
FWIW, I have been using the Motive on my 1973.5 for over 20 years with NO DRAMA.
I have the same bubble issue when I used a vacuum bleeder system.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-27-2023, 12:40 PM
this is the best power bleeder doen't put air into the fluid like the one's you pump up. https://www.tooldiscounter.com/product/power-probe-electric-pressure-brake-bleeder-25-gallon-pprstbbe25gal I have a shop and this is what I use and all the dealers. It's a honda factory tool
Old 01-27-2023, 03:22 PM
The best brake bleeder I have ever used has been my wife. Going on 37 years of faultless reliability.
I'm a big believer in the old pump and hold, two person bleeding method. I've long since lost track of how many spongy pedals on friends' cars I have firmed up by bleeding them the old fashioned way.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 01-27-2023, 03:33 PM
Bill Douglas's Avatar
I use speed bleeders. Makes it easy.
Old 01-27-2023, 06:23 PM
Whilst the option of borrowing your wife is likely the best solution, I have always done gravity bleeding with very good success.
I am of the belief that any of the bleeders just move too much fluid too fast through all the little orifices, angles and passages and so leave some microscopic bubbles in their wake.
I like gravity bleeding precisely as it has slow fluid motion (likely like your wife....no insult intended) and considering I use only Dot 5 silicone fluid, slow fluid motion is the way to go in my mind.
Cheap too...just a few length of tubing and some time.
D.
Old 01-28-2023, 07:20 AM
I recently purchased a Mityvac for the brakes. That’s after owning a Motiv for 15 years and using it exclusively. I wasn’t a fan of adding fluid into the Motiv canister as I’ve had instances where bubbles were introduced. It also adds another clean up step and when dealing with a corrosive fluid I’m just not a fan. So I had to undo the cap, add fluid and re pressurize every time I needed a refill.
With Vacuum you can top off the reservoir and start suctioning, as the reservoir drops you can keep adding quickly and easily until you’re done flushing. The downside is the seal between the tubing and the brake nipple aren’t the best so air does make its way in. I’ve also seen air pull through the nipple and caliper area but again none of this is introducing air into the actual system.
Mityvac makes a great vacuum brake bleeder.
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 01-28-2023, 08:51 AM
I would rather be driving
jpnovak's Avatar
I gravity feed bleed and then final pump method with my son as a helper.
The air compressor line to vent does work really well.
The Motive also works well.
I do not like the vacuum method because I always see airbubbles from the hose to nipple connection.
Old 01-28-2023, 09:09 AM
SCadaddle's Avatar
On the 911SC I wound up just doing a gravity bleed, then installing speed bleeders and one man operation with those. Worked like a champ.
On the 66 VW Bus I tried a brand new Motive power bleeder system. Seemed to work but had absolutely no brake pedal. Bled all 4 corners at least 3 times still no pedal. Apparently the drum brake master cylinder has pressure holding valves at the output lines that the Motiv couldn't overcome at 12-15 psi. Wound up bleeding the old fashioned way with a friend.
The Motiv sits in a box now. Their catch bottles with the cable are the bomb, they really are nice.
Old 01-28-2023, 10:20 AM
HarryD's Avatar
Interesting, I just did the rear brakes in my 1970 bus and we used a Motive Bleeder. Worked like a champ.
Are you sure your flexible brake lines are not restricting flow?
Harry
2020 MB E350 4Matic
Old 01-28-2023, 01:22 PM
I’m also a little bit embarrassed that I didn’t think of this also. I bought the motive bleeder also.
Old 01-28-2023, 01:49 PM
HarryD's Avatar
Also, the pressure in a hydraulic system has to bleed down, otherwise when you take your foot off the brake, the brake cylinder pistons will not retract.
Harry
2020 MB E350 4Matic
Old 01-28-2023, 01:57 PM
