-   -   SSIs and 2 in 1 out muffler - does hanger need modification? (http://forums.pelicanparts.com/porsche-911-technical-forum/1137047-ssis-2-1-out-muffler-does-hanger-need-modification.html)
Discseven 03-24-2023 07:15 AM
Engine is ‘85 3.2 in ‘80 911. Am going with SSI heat exhangers and a Dansk 2 in 1 out muffler (“partners” to 964 cams.) I failed to take measurements prior to disassembling old exhaust so am in the dark on new exhaust fitment.
Am wondering if the Dansk will hang on the stock hanger or am I going to see a need for a mod? If mod is ahead, is there an off the shelf part or am I making it?
mikesarge 03-24-2023 09:10 AM
Mine (1980 SC Coupe w/dansk 2 in 1 out on SSI) hangs in the stock location. The muffler straps were harder to get around the muffler, but it has been in place for a couple years now without issue
Cory M 03-24-2023 10:12 AM
I have the similar feedback. Muffler bolted up in the same location. The bolts provided with the straps were too short. I had to use longer bolts to pull it tight, The supplied bolts wouldn't reach.
Discseven 03-24-2023 10:36 AM
Mike...Cory... thank you guys. I happened to take a rough measure of the straps-to-the-muffler yesterdaty and it appeared to be a borderline reach. Led me to question the hanger.
Will do a dry run now to see what my strap/bolt scenario is.
http://forums.pelicanparts.com/support/smileys/wat6.gif
PeteKz 03-24-2023 09:33 PM
My experience was the same as Mike and Cory with the strap bolts being a bit too short, which triggered multiple bouts of mechanically-induced Tourette's Syndrome. :mad: I found a slightly longer bolt in my spare parts collection (hell, who am I kidding, it's practically a spare parts museum now), and got it on one strap. After tightening it, I was able to get the other shorter bolt in to the other strap.
One other bit of advice: loosely bolt up the SSIs to the heads and muffler with the straps loose too. Then wiggle it around and get everything in best alignment before gradually tightening everything down.
And another bit of advice: Make sure your SSIs will come with O2 sensor bungs installed, or install them before you put the exhaust together.
Discseven 03-24-2023 10:28 PM
Checked... Need bolts twice as long. Curious that URO sells these straps with the ridiculous fit. I spoke with URO yesterday and could get zero support over the phone. The requirement is to email them the question(s). Pelican was also no help as there is no technical information on the length of these strap or others. But credit to John in sales for having a go at it. PP did offer a return with a store credit. I'll make these straps work.
Thanks Pete for the added info. I did get the SSIs with the bung installed. And checked the fit of my O2 into it---its a fit.
PeteKz 03-24-2023 11:13 PM
Karl, the bolts don't need to be "twice as long" (unless you're joking), just 1/2" longer will do it.
Discseven 03-24-2023 11:49 PM
Pete, I squeezed my straps on by hand and bolts twice as long looked doable. Am not planning to rig some method of pulling the straps together. Just getting bolts that will reach and be done with it. I see that guys use the longer bolts then swap them out for the shorter. Any technical reason to do that?
Ian Comerford 03-25-2023 12:48 AM
I had the same experience and noted that after tightening everything down and the strap taking the correct shape the long bolts could be swapped out for the originals. It is the strap taking the shape of the exhaust that allows the use of original bolts. Hope this makes sense
Discseven 03-25-2023 01:06 AM
Makes sense Ian, thanks.
mikesarge 03-25-2023 10:25 AM
Yep- I’m running my OG bolts. I had to wrestle with the straps quite a bit, I imagine if you took Ian’s route instead, things would go a lot easier
PeteKz 03-25-2023 02:19 PM
Ditto what Ian said. After you thightwn them up, the straps conform the the muff closer.
fanaudical 03-25-2023 03:38 PM
Karl - Your engine rebuild must be close to being done if you're working on exhaust - congrats!
Discseven 04-09-2023 05:28 AM
Hey Jim... you're a bit early but I accept with appreciation. Candidly, am still fiddling with cams. Got 964's and they're providing a very interesting (time consuming) learning experience. Exhaust is also changed from stock. Thought looking ahead at exhaust parts would be a good idea. Got longer bolts to deal with initial pull in. Have yet to see how SSI heat exchangers meet with the Dansk muffler. A fit with nothing to deal with would be a welcome surprise.
