-   -   Can you post a pic of the rear on an SC engine? (http://forums.pelicanparts.com/porsche-911-technical-forum/113712-can-you-post-pic-rear-sc-engine.html)
Gunter 06-05-2003 09:11 PM
Can you post a pic of the rear on an '80 SC engine?
A pic of the backside behind the air box with AAV, AAR, Decel. valve, Frequency valve, and all the rest visible, preferably from an '80 SC, would be appreciated. :)
smestas 06-05-2003 11:27 PM
Here is the back of a '78 CIS. If you would like a larger image I can email one to you.
I hope this helps.
http://forums.pelicanparts.com/uploa...Spictur345.jpg
RazorRacer 06-06-2003 04:50 AM
Here is a link to a few. But it's a 78SC (not mine).
targa80 06-06-2003 06:05 PM
Here's the butt of my 80SC 3.0Lhttp://forums.pelicanparts.com/uploads/06engine4.jpg
ruf-porsche 06-06-2003 06:18 PM
Nice Butt Targa80
Is it always this clean?
targa80 06-06-2003 08:11 PM
Yes, especially since it went through a rebuild in 1999.
Gunter 06-08-2003 07:03 PM
Thanks Pat Henry: Good pic. I needed to see the line from AAV to the deceleration valve.
Platiporsch 06-08-2003 07:38 PM
I have a 80 sc and need some clarification on the distributor vac/ret vac.lines and which port the red [adv] goes and blue [ret] goes, if you have some close ups or can tell me where your hoses route to that would be great. PS. my car doesn't have cruise control and i think theres a difference when it comes to this regarding where the factory set up the hoses. thanks
Gunter 06-08-2003 07:49 PM
Platiporsch: If you look closely at the above pic, you'll see the red line behind the throttle body. The blue is slightly to the left of it. I took my cruise control out.
Platiporsch 06-08-2003 09:59 PM
I don't see the blue one , i do see the throttle switch to the left, tell me where does the vac. from youre warmup regulator connect? mine goes to one port on the other side [rear of car] between the air box and the throttle body, also which of the two dist. vac lines goes above the throttle plate and which goes below.thanks
targa80 06-08-2003 10:21 PM
try this link for a closer pic of the red dist vac line. I posted a picture at the end of the post showing the red dist vac line.
cruise control vac line
Gunter 06-10-2003 07:36 AM
My WUR vacuum line has been removed.
