Somatic Negative Optimist
A pic of the backside behind the air box with AAV, AAR, Decel. valve, Frequency valve, and all the rest visible, preferably from an '80 SC, would be appreciated.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Here is the back of a '78 CIS. If you would like a larger image I can email one to you.
I hope this helps.
Here is a link to a few. But it's a 78SC (not mine).
Stopped racing and became a drummer |
Heck, I’m only 5 not 71!
Here's the butt of my 80SC 3.0L
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
Is it always this clean? |
Yes, especially since it went through a rebuild in 1999.
Thanks Pat Henry: Good pic. I needed to see the line from AAV to the deceleration valve.
I have a 80 sc and need some clarification on the distributor vac/ret vac.lines and which port the red [adv] goes and blue [ret] goes, if you have some close ups or can tell me where your hoses route to that would be great. PS. my car doesn't have cruise control and i think theres a difference when it comes to this regarding where the factory set up the hoses. thanks
Platiporsch: If you look closely at the above pic, you'll see the red line behind the throttle body. The blue is slightly to the left of it. I took my cruise control out.
I don't see the blue one , i do see the throttle switch to the left, tell me where does the vac. from youre warmup regulator connect? mine goes to one port on the other side [rear of car] between the air box and the throttle body, also which of the two dist. vac lines goes above the throttle plate and which goes below.thanks
try this link for a closer pic of the red dist vac line. I posted a picture at the end of the post showing the red dist vac line.
cruise control vac line
My WUR vacuum line has been removed.
