Posting a tutorial on Rear window defrosters
Can anyone explain to me how to share recent learnings I ve assembled in a word doc with pictures etc
It looks like I could cut paste the text and than manually insert the pictures but I was hoping for an easier path? If its not doable then I ll find some time to cut/paste and insert Thanks Bob (Mr Rear Window Defog poster child)
1977 911-S Modified (3.0 SC Motor/Flares) Last edited by 7783911; 03-26-2023 at 08:09 PM.. |
You can save Word file as PDF document and attach it to a posting here... Might be the easiest and quickest way to share here for you...
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
I must be missing something, I can not attach a PDF or anything to a post, is it a permission issue?
1977 911-S Modified (3.0 SC Motor/Flares) |
I see, there are some impediments here in the forum, especially with attachments. Either you have your PDF on a one-click-file-hoster, or on an free accessible web space or similar. Then you put the file there and post the link to it here in the forum.
Another option: Have a screenshot and post it in here (depends on the size,. bigger files better outside of pelican). I personally love "Greenshot" as screenshot tool (includes an upload function to imgur.com). Thomas
Painful
I ll hold onto the document and if anyone ever posts about rear defrosters I ll mail it to them or I ll see if I can share via one drive danke
1977 911-S Modified (3.0 SC Motor/Flares) Last edited by 7783911; 03-27-2023 at 10:48 AM.. |
new post created
here is the document if you wish to review and comment https://1drv.ms/w/s!Av4B-0xq22s6zSYLjItEO_0AOGRO?e=2pFAW5
PCA Member since 1988
7783911: Thanks for posting that. I copied it to my files and printed a copy for the shop manual.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Appreciate this.
