cilinder head temp.sensor
Is it possible a failure in the cilinderhead temp.sensor that my 3.2 1986 carrera is not starting when the engine is warm
yes, that can be a cause, but a failing head temp sensor generally affects the engine when it's cold, not hot -- more frequently, this is a symptom of a failing DME Relay. Do you have a spare DME relay and, if so, have you tried swapping it out? (everybody that has a 84-89 Carrera should purchase and carry with them a spare DME relay, as vibration causes their soldier joints to fail, resulting in no-start situations). If you don't have a spare DME relay, worth tapping on it (it's under the driver's seat, behind the DME computer) while trying to start and seeing if that makes any difference.
Could be CHT, Speed or Reference Sensor, DME Relay.
I would take a multimeter and check each one at the plug on the driver side. There are 3 plugs connected on the holder on the intake. Do you have the manual for the specs each should have. If it is CHT as it is temp related get one of these: https://www.amazon.com/dp/B07VBQFFG2?psc=1&ref=ppx_yo2ov_dt_b_product_details Cheap CHT remover and installer. Im leaning toward relay. |
actually the number one failure of CHT is when engine is warm it chokes and stalls out. If this is your issue, jumper it with a paperclip at the connector ( i think its the top white one but someone will chime in if i am incorrect ) . If car starts and runs no problem that is your issue. Every 3.2 should have a paperclip in the tool kit, this trick could get you home in an emergency, remember to remove the paperclip when engine is cold of course.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Its the top white as theiceman says. but do an ohm check on it.
CHT Sensor Resistance from Bentley * 0C = 4.4 to 6.8 K Ohm 15C to 30C = 1.4 to 3.6 K Ohm 40C = 1.0 to 1.3 K Ohm 80C = 250 to 390 Ohm 100C = 160 to 210 Ohm 130C = 90 Ohm Characteristic Application T [°C] R [Ohm] -40 45,313 -30 26,114 -20 15,462 -10 9,397 0 5,896 10 3,792 20 2,500 30 1,707 40 1,175 50 834 60 596 70 436 80 323 90 243 100 187 110 144 120 113 130 89 |
