kramer747's Avatar
glove compartment door
How do you remove the door? I want to take it off to reglue the backing that is separating from the front surface of the door. Do they sell new ones? I didn't see any on Pelican
Old 04-18-2011, 04:41 PM
Member 911 Anonymous
DRACO A5OG's Avatar
You will need to remove the knee pads to gain access to the bolt on the hinges of the glove box door.
Take care the bolts tend to be pretty tight and can easily strip the head round. Ask me how I know.
I have an extra one if you want it cheap plus shipping.
Also if its spreading I fix mine with some adhesive and used wood clamps to dry over night, worked well, just make sure you place a piece of wood to spread out the pressure, if not the clamps will dent the padding.
Jim
'85 Carrera Targa
PCA/POC
Old 04-18-2011, 06:07 PM
kramer747's Avatar
ok thanks. So when you open the glove compartment and look inside -those screws in there are not holding it in? Is the knee pad hard to remove?
Old 04-18-2011, 06:41 PM
DRACO A5OG's Avatar
Knee pads are very easy, just reach behind the pads and you should feel 4 small bolts that hold the pad in place.
Once pads are removed and you open the glove box, it will open about 180 degrees then you will see the bolts that hold the glove box. If I had to do it again I would tap the bolts to break them loose before putting a socket on them to remove it.
Jim
'85 Carrera Targa
PCA/POC
Old 04-18-2011, 06:45 PM
muck-raker
kidrock's Avatar
I did this repair recently, without removing the glovebox door or the kneepads. Since the cover was already separating from the door, I removed it completely by removing the lock/latch mechanism and pulling the cover off. I cleaned the metal door, applied contact cement on the door and cover, pressed them back together and held them together for 24 hours with some 1"X2" wood and carpenter's clamps.
Works like a charm, easy as cake and looks great.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-18-2011, 06:55 PM
DRACO A5OG's Avatar
Yeap, this is what I did
Once I stripped the head on one bolt that is
'85 Carrera Targa
PCA/POC
Old 04-18-2011, 06:59 PM
muck-raker
kidrock's Avatar
Well, now that YOU admitted it, I guess I might as well admit it too.
STONE
Old 04-18-2011, 07:01 PM
DRACO A5OG's Avatar
Great Minds....................
'85 Carrera Targa
PCA/POC
Old 04-18-2011, 07:04 PM
kramer747's Avatar
ha! maybe i will just leave the door on and try to fix it in place! Just regular contact cement?
Old 04-19-2011, 04:29 AM
muck-raker
kidrock's Avatar
Yup, contact cement. Get the good stuff, don't get the cheap crap.
STONE
Old 04-19-2011, 06:11 AM
+1--I re-glued my door while in place. And depending on the amount of separation, it may not even be necessary to remove the cover completely from the door. I re-glued mine in stages--one side, then the next, etc. Turned out fine. I used the Wurth Black Weather Strip Adhesive I already had. It has the advantage of matching my black interior so you can't see any contact cement residue (usually a lighter color) at the edges.
Jon
'85 930
Old 04-19-2011, 06:40 AM
rfloz's Avatar
My adventures with glove box door removal - in excruciating detail:
Removing Glove Box Lid - Not So Easy!
Have fun.
Bob F.
1984 Carrera Factory Turbo-Look
Old 04-19-2011, 08:08 AM
muck-raker
kidrock's Avatar
Have fun.
Funny stuff, Bob. What a PITA. I can't believe that thing weighs so much.
STONE
Old 04-19-2011, 01:20 PM
TIG Welder
doublestuff's Avatar
I had a head start, but I just went out and pulled mine in about two minutes (79 SC).
My kneepads were already out of the way. The two phillips head screws facing out from the box were pretty stripped from someone's prior attempt to remove this, but I found that if I used a screwdriver to hold the screws in place and used a socket wrench to actually turn the nuts on the back it worked fine, they came out very easily. This might be because someone already had them off in the past, not sure.
Jason
'79 SC Targa (SOLD)
'85 944 (SOLD)
'86 951 (SOLD)
'97 Boxster (SOLD)
Old 04-19-2011, 03:19 PM
DRACO A5OG's Avatar
^^^^ you lucky
'85 Carrera Targa
PCA/POC
Old 04-19-2011, 06:26 PM
kramer747's Avatar
Thanks everyone - I did it today without uninstalling it -worked like a charm
Old 04-24-2011, 07:14 PM
DRACO A5OG's Avatar
Great! Glad it worked for you
'85 Carrera Targa
PCA/POC
Old 04-24-2011, 08:31 PM
muck-raker
kidrock's Avatar
What? No pix?
STONE
Old 04-25-2011, 07:45 AM
kramer747's Avatar
ha ha- I figured for you experts it was too basic of a "repair" to warrant pics. I did use Goop brand contact cement FWIW!
Old 04-25-2011, 10:21 AM
Any updates on glue? You know, a brand that is still working or one that is no longer working. I used liquid nails and was not happy at how long it (didn’t) last.
Brock
P.S. it gets hot here in the summer so that could have had something to do with it.
Old 03-24-2023, 06:20 PM
