OsoMoore's Avatar
Gas leak at first spring start
I started my SC up for the first time this year, and after clearing the garage around it, spotted a 3-seconds-per-drip leak coming from just inside the front passenger wheel.
It is clear, and smells to be gas.
It only started when I started the engine. I haven't had a chance to get underneath yet, and I'm not sure I even want to start it again before fixing.
Any tips on what to look for and what it may be would be appreciated.
Old 03-23-2019, 09:56 AM
7783911's Avatar
fuel pump connection to hose..started up puts on flow pressure...gas running along a sill to the point it can drop to ground?
Old 03-23-2019, 09:58 AM
Locating fuel leak........
OsoMoore,
Test run your FP and you will locate the source of your fuel leak. Keep the FP running and begin your investigation. The drip area will direct you close where the source is located. Do not start the engine until you fixed the leak.
Tony
Old 03-23-2019, 10:09 AM
OsoMoore's Avatar
Originally Posted by boyt911sc View Post
OsoMoore,
Tony
Excellent plan! I already know how to start the fuel pump on its own, by lifting the air flow sensor plate with the key slightly turned.
Old 03-23-2019, 10:14 AM
Mark Salvetti's Avatar
I wouldn't use the air flow sensor plate to run the pump. That will also squirt fuel into the cylinders. You need to pull the fuel pump relay and use a piece of wire to jumper across terminals 87a and 30.
You'll also need to jack up the front of the car and remove the skid plate to expose the fuel pump and the hose connections.
The easy one to fix is the rubber hose on the suction side of the fuel pump, but since the leak is on the pressure side (or it would be leaking without the car running), you may have some challenges. Hopefully it's just a loose connection. If it's a crimp between the rubber hoses and the tunnel lines, you'll have some work ahead of you.
Mark
1979 911SC Targa
Old 03-23-2019, 10:17 AM
OsoMoore's Avatar
Mark
Oh right. I forgot about flooding the cylinders.
The fuel pump relay and I are old friends… I have the skid plate off now, I'll jumper it and see what we see.
Old 03-23-2019, 10:28 AM
I had a similar leak last summer and it was the clamps on the hose 7783911 mentioned. They had rusted/ broken leaving the hose too loose at the fuel tank connection. Easy fix and hopefully you find something similarly easy.
Old 03-23-2019, 10:43 AM
OsoMoore's Avatar
I did the jumper dealio and located exactly where it is leaking from.
I'm going to do some digging into where that line goes to next.
Also, for the benefit of those who come later, here's how you jumper your fuel pump relay. Do this thing, and then turn the key half a turn. Touch the wires together and she runs. The pin numbers should be written on the inside of the fuel pump relay itself, the order of the relays may vary, and the FP relay will generally be your only red relay.
And always have your fire extinguisher nearby when messing with gasoline.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 03-23-2019, 10:48 AM
7783911's Avatar
could you observe the leak occuring? time for a new hose unless it can be recrimped which generally (i am told) doesnt work. or can you run hose direct to barb and clamp?
Old 03-23-2019, 10:54 AM
7783911's Avatar
ps..is that a Klassic fuse panel?
OsoMoore's Avatar
Here's a less disorienting photo:
I observed the leak coming directly from the circled spot, at the crimp.
It is a fuse panel rebuild I did myself, with some help from the PP forum. Here's my thread on it.
Sick Of It! Time to update my SC Fusebox
Old 03-23-2019, 11:03 AM
OsoMoore's Avatar
I found some good info on I've searched but still need help fuel leak.
My leak is the high pressure feed line... oh boy.
EDIT: Collecting threads on how to do this... fun times ahead.
Top thread: Okay- so I am going to replace my main tunnel fuel lines tomorrow. Any suggestions?
Other Threads:
How hard is it to change the fuel lines?
Should I replace theses brake and fuel lines?
Old 03-23-2019, 11:13 AM
Functionista
manbridge 74's Avatar
New lines have an upgraded double crimp. FYI
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 03-23-2019, 11:29 AM
Ouch!! I am having both tunnel lines replaced in a couple weeks to avoid this exact issue. Lots if good words about replacement lines made by Len in NH (boxstergt)
Old 03-23-2019, 11:30 AM
7783911's Avatar
I can vouch for Len...great guy to deal with!
Old 03-23-2019, 11:55 AM
beren's Avatar
Happened to me 3 years ago on the first drive. Was a ruptured fuel line, which I had to partially drop the engine to get in there to replace it. It was a good excuse to replace them all and the sound dampening material. I basically changed out any rubber thing I could when I did that.
Old 03-23-2019, 02:29 PM
Nope..........
OsoMoore,
This is a bad procedure to use when you are looking for source/s of the fuel leak. Why would you dump fuel in the combustion chambers when you could run the FP without the fuel injectors delivering fuel. Using the FP socket’s terminals #30 & #87A would be a better option.
Tony
Old 03-23-2019, 04:18 PM
OsoMoore's Avatar
After an analysis, I'm going to replace the full fuel line set. I've talked to Len and am sending him an order later today. In the meanwhile, I'm working on draining the fuel and getting set up to access all the tight areas.
I'm thinking about dropping the steering stuff out of the way. Has anyone who did Len's lines done it with that in?
Old 03-26-2019, 06:29 AM
OsoMoore's Avatar
I've borrowed 3 gas cans and some very large jacks from a friend. New lines are on order from Len, hopefully arriving by next weekend. Tonight I'm going to go for a fuel drain.
The current plan is to tape the hell out of the leaky spot just after the fuel pump and put a pan under in case it leaks some more. Then I'll detach the fuel line in back at the accumulator. Then I can stick the line in a can back there, and lift the air flow sensor plate to activate the pump. That should allow me to control the dumping of fuel into the cans. I don't have to mess with hoses while on my back under the car, and I can stop easily to switch to new cans.
I'll report back tomorrow!
Old 03-29-2019, 08:03 AM
Jeff NJ's Avatar
I did Len's lines with the steering assy in. It was a pain and there was much cursing and gnashing of teeth, but I believe it was faster than removing the steering and maybe helped avoid a separate can of worms while removing/reinstalling the steering assy.
Be sure to get the grommets for the tunnel lines and his threaded coupler to help pull the tunnel lines through while removing the originals.
1988 930 Venetian Blue
Old 03-29-2019, 09:03 AM
