A/C causing stalling when engine cold
I've upgraded the A/C on my 1980 911SC. Rotory compressor, new hoses, etc. It works great, but I'm having trouble when using the A/C around town. My engine is constantly stalling when having to stop at a light, etc.
Is there a idle sensor somewhere going bad or does my fuel injection system need adjustment? Idle is set for 900.
Old 06-06-2003, 12:10 PM
ruf-porsche's Avatar
What type of compressor did you upgrade to? Is it a Seki Seiko?
Is your idle without the ac on set for 950 to 1000 rpm? If the idle is set below 950 that could be your problem.
Old 06-06-2003, 12:28 PM
Sanden wobble plate, I'll check the idle...thanks.
Old 06-06-2003, 12:38 PM
