Harpo's Avatar
Wire harness plug instalation trouble
I purchased new tail light assemblies but getting the plug back into the body has been impossible
Old 11-20-2020, 12:04 PM
Put liquid or jelly silicone on the tapered end and push like hell (but try not to get any on the electrical contacts). The connector body there should be a stiff rubber (it was originally). Good luck if it's now plastic...
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 11-20-2020, 12:32 PM
ROW '78 911 Targa
timmy2's Avatar
Glycerine and twist/turn as you push. And yes, push hard...
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-20-2020, 01:25 PM
Prestallion's Avatar
Isopropyl alcohol works great as a lubricant for installing rubber plugs, grommets, etc.
Old 11-20-2020, 02:16 PM
dlagerstrom's Avatar
+1 for glycerine
Porsche even put a bottle of this stuff in 356s. Great to keep rubber supple and as a lube. Evaporates fairly quickly.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 11-20-2020, 05:44 PM
I used dish soap and a pick to install mine. I lost some skin doing it though.
Old 11-20-2020, 05:49 PM
warm it up with a heat gun, dab of dish soap...works every time.
Old 11-21-2020, 03:18 AM
anyone have the male end of this plug, inside the rear compartment, showing the wires? need to see the order of the colors.
Old 04-10-2023, 06:14 AM
It only plugs in one way.
Old 04-10-2023, 08:17 AM
The female side housing fell apart now I have loose wires not knowing what order to put them back into the male side
The wires other side right side of the car are not visible in its housing..so I can compare
Old 04-10-2023, 09:49 AM
this is the order I attempted..didnt work
Old 04-10-2023, 09:52 AM
