Smoke from carbs, redlining at idle
Oddest thing is happening right now… drove my car down to Target for a booster shot. Zero problems on the way here. I get poked, head out, and the engine is doing its best to sit at redline like the throttle is stuck open! So I pull over, pop the deck lid, and realize that smoke is coming out of my carb hats. It smells HEAVILY of fuel. The throttle is indeed sticking, but not just open - something in the carbs is binding and doesn’t want to let it turn easily. The linkage all moves freely - whatever the problem is, it’s in the carbs.
Additionally, from looking through the glass into the bowls, I can see bubbling fuel… and it’s low. Plenty of gas in the tank.
So, before I call a tow truck, anyone have any ideas?
(‘81 3.0L w/ PMO carbs)
http://forums.pelicanparts.com/porsche-911-technical-forum/1114917-jedi-911sc.html
Old 04-12-2023, 03:03 PM
Don’t know what tools you have available with you, l would separate the left and right carbs to try to isolate the issue. Also one of your float needles may have stuck, perhaps tap on the side of the float bowls to unstick
Good luck
Pete
Old 04-12-2023, 03:12 PM
Good luck
Pete
Had a similar thought. Started the car and it fired up with no issues. Disconnected the linkage, still idles fine. Tried to move both of them through the full range of motion, no issues on either. Reattached the linkage, went through the motions, again, no problems. Driving it home.
edit: Made it home with no issues.
Additional info: daily driver, ethanol-free gas only. Carbs new - installed under a year ago. Brown discoloration forming on exterior of carbs. Phenolic spacers that came with the kit are installed. Not overheating:
Old 04-12-2023, 03:29 PM
Glad you made it home! Quite the mystery. Perhaps check for the proper level of fuel in the float bowl and that all linkages are moving with no binding and smoothly all the way back to the gas pedal.
Old 04-12-2023, 04:34 PM
PCA Member since 1988
If it was an airplane, I'd think you had carburetor icing, which stuck the throttle open until the ice melted. It can happen on carbureted cars too. Was the weather cool and damp?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-12-2023, 04:46 PM
~75*F, 14% humidity. 45 minutes of driving followed by 30 minutes of sitting in the sun.
Old 04-12-2023, 05:15 PM
Just a guess, could be that one or both throttle shafts are bent or binding. Possible result of the carburetor being unevenly or over torqued to the manifold.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 04-12-2023, 05:55 PM
Not sure about you’re problem, but that tach is killer more info please
Old 04-12-2023, 06:19 PM
Speedhut.
this one, if I recall correctly. 3D printed ring needed to seat it properly.
Old 04-12-2023, 07:10 PM
You have zero oil pressure at idle? Even hot is that normal?
Old 04-12-2023, 07:29 PM
Dunno, been like that the whole time I’ve had this car. No issues with oil pressure when cold, but once it warms up, that gauge goes to zero and the oil level and temp gauges start working.
Old 04-12-2023, 07:36 PM
Tell us about your carb install, pump/ regulator/lines/ return. You have some percolation going on.
And why are you still letting them stick you with that crap??
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 04-13-2023, 06:36 AM
Maio Car Die Tus
Old 04-13-2023, 01:45 PM
flat6pilot's Avatar
Glad it's working again!
Can I get a closeup of your RPM gauge? What are the idiot lights listed on the right. And who did the mod for you? Is that a tell-tale I see?! maybe a reflection.
Kyle
1980 911sc 3.2 Turbo, 930 Trans
2006 BMW 330i 6mt (DD)
Old 04-13-2023, 04:17 PM
Is that a normal oil pressure? 0 at idle?
Just curious.
Old 04-13-2023, 04:52 PM
The idiot lights on the tach are just a shift light setup. I installed the tach and designed/printed the mounting ring myself. I've got it sync'd off the coil instead of the CDI+ since I didn't have the CDI+ when I bought the tach. Not sure what a tell-tale is.
Just curious.
No idea. It's only 0 at idle once it's warmed up. And I verified today, @ 4K RPM it's showing 3 on the pressure gauge once warmed up, so it's still working.
As another update, the car is still running perfectly. I don't know what the heck happened, but it seems to be over it.
Old 04-13-2023, 05:04 PM
Did a rock or something get stuck somewhere holding the throttle open? Weirder stuff has happened.
Old 04-13-2023, 05:50 PM
Speedhut tachometers:
https://speedhut.com/categories/gauge-applications/revolution-racing-performance/led-lit-gauges/performance-led-tachometer.html?_ga=2.201976273.1781889820.1681433 490-717221399.1681433490
Old 04-13-2023, 05:58 PM
