Paul Shepherd's Avatar
Occasional Start Problem
86 3.2 Carrera. Very occasionally although seems to be getting more frequent when I turn the key I just get a click with the dash lights coming on. First few times I thought it was a flat battery and charged it up because that’s exactly how it looks. Try it again and it always starts. Probably happens about one in ten times but want to sort it before it leaves me stranded. I’m thinking maybe starter solenoid or ignition switch??
Any help appreciated
Old 04-17-2023, 01:24 AM
Kind of Blue
MrBonus's Avatar
I made basically the same thread a few months ago. Could be the tranny ground strap, starter solenoid, starter, ignition switch (in roughly that order).
Good luck!
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 04-17-2023, 02:56 AM
Schulisco's Avatar
...not to forget the starter solenoid contacts...they often get dirty over time and then the ignition and the starter switch are working, the starter enggages but still nothing happens...
Also 964s and 993s are also mostly known for a stucked cog in the flywheel, probably also a potential issue on G body cars?
Follow the wire diagram with a multimeter to narrow the problem...
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 04-17-2023, 07:19 AM
Check out my thread on hot start problems
Roy
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 04-17-2023, 08:41 AM
