Part ID needed- harness pins
Anyone know the name / size of these pins in the harness connector?
Where can I purchase them? thankshttp://forums.pelicanparts.com/uploa...1681761123.jpg |
I could be mistaken but I don't think the pins themselves are replaceable. They are called a 6 pole/pin relay plug connector. I recently replaced my rear turn signal harness connectors with the one SMC offers - https://rb.gy/8abqi. Pretty good quality and it's a much tighter fit than OEM, which I like. Part number is 901.612.330.00
Agreed. This is a molded assembly, so there is no access to the back of the pin where the wire is soldered or otherwise attached to the pin. It isn't like the 14 pin rectangular connector back in the engine compartment which was made so it could be disassembled, and things moved around or pins/wires replaced.
Only way to get the male pins is by buying the 14 pin connector kit.
Not available separately…. https://www.pelicanparts.com/More_Info/91161211305.htm?pn=911-612-113-05-M100&bc=c&SVSVSI= Female Pins are available separately at almost $3 a piece! |
ok thanks
| All times are GMT -8. The time now is 02:13 AM. |
