Part ID needed- harness pins
Anyone know the name / size of these pins in the harness connector?
Where can I purchase them? thanks
I could be mistaken but I don't think the pins themselves are replaceable. They are called a 6 pole/pin relay plug connector. I recently replaced my rear turn signal harness connectors with the one SMC offers - https://rb.gy/8abqi. Pretty good quality and it's a much tighter fit than OEM, which I like. Part number is 901.612.330.00
Brewster Green 1977 911S Outlaw Hot 2.7|10.5:1|Single Plug|Knightrace Cams|Weber IDA40's|SSI's|MSD Ignition Engine Built by Will Pyle Instagram: indy.alex.g Last edited by IndyAlex; 04-17-2023 at 01:09 PM.. |
Agreed. This is a molded assembly, so there is no access to the back of the pin where the wire is soldered or otherwise attached to the pin. It isn't like the 14 pin rectangular connector back in the engine compartment which was made so it could be disassembled, and things moved around or pins/wires replaced.
ROW '78 911 Targa
Only way to get the male pins is by buying the 14 pin connector kit.
Not available separately…. https://www.pelicanparts.com/More_Info/91161211305.htm?pn=911-612-113-05-M100&bc=c&SVSVSI= Female Pins are available separately at almost $3 a piece!
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 04-17-2023 at 05:23 PM.. |
ok thanks
| Tags |
| connector , pins , plug |
