here’s one! electric windows
began yesterday.. parking my ‘85 911 …. i WAS ALWAYS able to “roll” up my windows with the key in the off position …UNTIL a door is opened.
Once a door is opened I needed to turn the key on to put up the windows. NOW with key off and PRIOR to a door being opened the window switch will not roll up the windows. what could have happened? |
Relay went bad?
Door (light) contact switch stuck or dirty ? Had that occur once or twice on a Ford or BMW. Think I disconnected the battery and it reset the ECU. |
The ECU on the 911 has nothing whatsoever to do with the windows.
Will the passenger side move up and down? If so, it is not the fuse. Likely the switch itself, they are not robust at all and can and will fail.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
i will try to make my issue easier to understand
This is how my window always worked BEFORE my issue: i could turn off the car off, key off, the windows would still work UNTIL i opened a door. NOW: when i turn off the car the windows do not work PRIOR to opening a door. the windows work! but not with the key off, unlike before Last edited by jgurnari; 04-21-2023 at 02:14 PM.. |
That sounds like the way a late model car works.. not an 80's 911... I really didn't think they were equipped with that feature.
Does your car have an aftermarket immobiliser?
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
are you sayin the windows go up an down with no key or key off with doors open? with doors closed, key off, the windows don’t work?
immobiliser?
don’t know what that is. regardless, it was working but stopped. was nice to be able to turn off the car and close windows without having to turn the ignition on again... especially when my passenger forgets to close the window prior to getting out.
anyone know how to fix window issue so that the windows will go up and down with the ignition off?… with the doors closed.
Edit: 85 and 88 work differently, as I discovered by reading this old topic and this one. Last edited by wazzz; 04-22-2023 at 08:23 AM.. |
Thanks wazzz...Figured it out from your link! I put the interior lights in the position of, lights come on when doors are open.
| Tags |
| window switch |
