-   -   1982SC- calling front hood latch gurus (http://forums.pelicanparts.com/porsche-911-technical-forum/1138596-1982sc-calling-front-hood-latch-gurus.html)
OldSpool87 04-20-2023 05:02 PM
My front hood sits with a noticeable gap of about 3/8” in the front where it meets the bumper. All other lines look good. When latched and I press down, it feels like the male portion of the latch assembly connected to the hood bottoms out too early on the catch part mounted to the car (if that makes sense). There’s no downward “give”, so I’m ruling out the two rubber stops.
All this said, is this merely a matter of loosening the two latch screws on the female latch assembly connected to the car to allow the hood to close further downward? I’m cautious only because I adjusted the fore/aft of the hood at the hinges (successfully) but felt I was toying with Satan the entire process. I don’t want to go there again.
[IMG]https://uploads.tapatalk-cdn.com/202...33d4471035.jpg
[/IMG]
https://uploads.tapatalk-cdn.com/202...6c5bacd974.jpg
dannobee 04-20-2023 05:21 PM
Where's the black sealing strip that goes on top of the bumper?
OldSpool87 04-20-2023 05:48 PM
It’s a fiberglass aftermarket bumper installed by PO. Kinda 964-esque. Never had that top strip.
1989Carrera 04-20-2023 07:11 PM
If you lower the latch as you described, you will ruin the alignment of the hood to the fenders. Not the gap between the hood and the fenders, but where the top of the hood meets the edge of the fenders. To eliminate that gap you'll either have to figure out how to fit the factory rubber "smile" or do some surgery to your front bumper.
proporsche 04-20-2023 11:10 PM
try to adjust the rubber stop on each front corners,they could be possibly to high
Ivan
JSV798 04-21-2023 03:20 AM
Refit an original bumper and smile and dump the after market one.
dailydriven911 04-21-2023 05:59 AM
Put a 964 smile on there and call it good
OldSpool87 04-21-2023 08:19 AM
Very helpful. 964 smile option seems to be the path.
Thanks to all for the input.
