Carrera chain tensioner chain box cover fitment issue
Has anyone ever ran into a fitment issue with the aluminum chain box covers that come with the pressure fed Carrera tensioner upgrade kit?
The right side (passenger) cover went on without any issues but the left side (driver) seems to be hanging up close to where the tensioner exits the chain box cover. The tensioner itself fits through the hole in the chain box cover without any issues (see first image below), but it appears the hole with the aluminum cap (just above and to the right of the tensioner exit hole) isn't quite lining up with the idler arm / tensioner shaft (see images below). Wondering if this is a manufacturing / tolerance issue with the chain box cover itself or if something might be wacky with the tensioner / idler arm shaft alignment? If anyone else has experienced this issue or has any workarounds, I'd love to hear them. Thanks! ![]()
did you lubricate the o ring? Looks like you did not go deep enough with the cover.How does the cover look on the inside-picture?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Yes, lube o ring and tap in that spot with soft faced hammer
New Batch of Carrera Hydraulic Tensioner………
First, try to install the chain housing cover without the hydraulic tensioner and observe the fitment. Next, try with the Carrera hydraulic tensioner installed. Do you have a new hydraulic tensioner? Try to install an old tensioner and compare. The new batch of tensioner might have changed a bit.
Tony |
measure the shaft-that should be just like any other shaft ..after measure the hole on chain housing cover.Again it should fit .I just did today the same engine as yours...
![]() new tensioners -they look totally the same --Did not see any difference as Tony has mentioned? Ivan
That hole looks a little funky hard to tell from your pic, is there a bevel around the hole concentric to the hole? Area where your arrow is looks a little odd.
If you want to see how far off it is heat the area around the plug pop it out and assemble, that way you can see through the hole where it’s getting hung up, then go from there.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
if i remember correctly that post is removable and epoxied in. I seem to remember rotating mine so it would wear on the other side. But i might have misremembered that lol... If so take out post and repoxy it a .5mm over a bit
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
i find sometimes there might be just enough play with these kinds of things
PCA Member since 1988
Off the top of my head: Make sure you have the tensioner all the way in, and that the sprocket is all the way in, and that the chain is centered on the sprocket. Did you leave the installation clip in the tensioner?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Hi Pete - yep all that was checked (and I had pulled the installation clip earlier as well). I finally got it on. I had to tilt the cam cover a bit towards the top figuring it would give me just a bit more clearance on that hole. That was all I needed to do. Then just a few taps with the mallet and it was on. Guess the tolerance on that hole was just barely off a bit.
Ivan
Finally got the cover on - had to tilt it a bit towards the top and then give it a couple of light taps with the mallet. That tilt helped the shaft get the clearance it needed to get in the hole.
Thanks for everyone's input. Tapping and angling the cam cover (as needed) seems to do the trick. |
great to hear...
| Tags |
| chain cover tensioner , chain covers , hydraulic tensioner , pressure fed tensioner |
